Current bugs 2.00100
wtin
Post by wtin »
1. Program does not refresh the bitrate.
Steps to reproduce:
Use any profile.
Import a few files.
Each file shows current bitrate.
Import a few more files.
Bit rates are calculated for the new files only.
Switch to another profile. Bitrate is refreshed.
Switch back to the profile you want to use. Bitrate is refreshed.
2. Subtitle files aren't processed if more than one type presents.
Steps to reproduce:
Use blu-ray profile (mine is custom - hard subtitles).
Import a few files.
Choose the subtitle for each file (chapter).
Click [start], and click on the file that is being encoded (to look at the preview]
No subtitles are progressed.
Workaround is to make sure there is one type of subtitle for that file. Either SRT or ASS, but not both.
Hardware/software: Windows 10 64 bit. dual Xeon E5-2680 v3, 128 G of RAM and Quadro K5200.
Re: Current bugs 2.00100
Hi there,
Thank you so much for this post!!
You won't imagine how much you makes it easier for us (clear & brief description, step by step)
Bugs will be tested and reported asap.
Cheers,
