CMD command line change settings PAL/NTSC
vasjagubin
Post by vasjagubin »
Hello
I'm using a simple batch script in DOS in order to convert files to DVD.
for /f "tokens=*" %%a in (found.txt) do (
echo Converting %%a
"C:\Program Files (x86)\VSO\ConvertX\7\ConvertXtoDvd.exe" /file="%%a" /auto=true /close
How can I change the video format from PAL to NTSC and vice versa using that script? I really appreciate your help. Thanks in advance.
Re: CMD command line change settings PAL/NTSC
Interesting. CXD supports command line switches, which I wasn't aware of, yet, /? does NOT display a list of available switches.
@vasjaqubin.
I have passed your query to one of the coders.
Still no reply.
vasjagubin
@dbminter
It simply opens the program without any output on the command line.
@Coral
Sounds great!
/? also just opens the GUI.
vasjagubin
dbminter wrote: Wed Nov 11, 2020 1:28 pm /? also just opens the GUI.
correct
vasjagubin
Coral wrote: Wed Nov 11, 2020 8:20 am @vasjaqubin.
Still no reply.
Hi Coral, have you received any feedback from your coder?
vasjagubin
Still no reply.
Sorry. No reply whatever 😐
