Hello
I want to clean install my PC's Windows, so I try to Revoke CXD Registration, but it has no effect, I revoked the registration but CXD is still registered,
what's wrong and what's the solution?
Problem Revoking...
- VSO Fanatic
Re: Problem Revoking...
Which version of CX are you using ?
Have you formatted your HDD ?
- VSO Fanatic
While installing, have you selected the 3 options for a clean installation ?
Reinstalling Windows over the old installation (without formatting) could leave the validation of CX active.
- VSO Fanatic
