I set up my video conversions, and them them as the project,to convert at a later time and date , so my wife may use the laptop. After the project is completed, i either delete the original files, or move them to an external drive. 192168101.com
There is , on the main menu, no delete function for completed projects. I did a search thru windows and found some. delete them. Still showed in the load projet. was told to go to output folder and delete my files. I moved them , and renamed them. still showed the project. 19216811.dev
Is there an easier way to remove the project from the load project
Thank you for help
Delete Project
Re: Delete Project
When you save the file, to conveert later, it is saved as as big X with what you named it. Delete that. Cant see how it stays in a project if you delete what you convert.
