DTS-HD audio automatically converting to AC-3
mjvmovieman
Post by mjvmovieman »
Hello. I was wondering if someone could help. I'm using the latest version of CovertxtoHd, and my DTS-HD audio 5.1 and 2.1 audio streams are always converted to AC-3 Digital 5.1 or 2.1. I have the "Convert DTS" box unchecked, and it's still doing it.
It there a way to ensure the DTS-HD audio is not changed?
Also, is there a way to preview the output of the conversion before it is burned to disc? Thank you.
mjvmovieman
Re: DTS-HD audio automatically converting to AC-3
Update:
5.1 DTS-HD and 5.1 Dolby-TrueHD tracks can successfully convert untouched, but I've tried a 2.1 DTS-HD track and 1.0 MA-HD track separately and they both down-convert to AC3.
Is this a bug, and if so, can it be fixed?
Found this:
DTS-HD Master Audio may be transported to AV receivers in 5.1, 6.1, or 7.1 channels
and
DTS-HD Master Audio, previously known as DTS++, is the second of two DTS-HD audio formats. It supports a virtually unlimited number of surround sound channels, can deliver audio quality at bit rates extending from lossless (24-bit, 192 kHz) down to DTS Digital Surround and, like Neo, downmix to 5.1 or 2.1 systems.
It looks like there is no 2.1 DTS-HD MA. Amplifier can downmix to it. In this case, CxD does mixing to AC-3.
