DVDs are not burning?
robertg_s
Post by robertg_s »
Long time registered (for lifetime) user here. Tonight all of a sudden will not burn to either of my DVD burners.
This is what comes up and I keep getting prompted to insert a DVD (does not seem to see any DVD and I have tried several that have always worked even earlier on today).
Could it be Microsoft has done something or do I need to completely uninstall the program.
Scanned files #9, folder #2 - total size 2766989312 b. (2.58 GB.)
Inserted media type : dvd+r
Volume ID: 7397
Folder: C:\Users\Robert\Documents\ConvertXtoDVD\7397\
Write started
DVD Video burn process started
Writable disc dvd+r inserted. Ready to write
Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
Drive has USB physical interface
New Drive selected : [F] TS8XDVDS TRANSCEND 1.00 (USB)
No disc in drive.
Drive has Serial ATA physical interface
New Drive selected : [D] PLDS DVD+-RW DU-8A5LH 6D1M (SATA)
Thanks for any help.
Robert
Re: DVDs are not burning?
What happens when you try to burn?
Log shows that internal D: has a dvd+r and external F: is empty.
robertg_s
Post by robertg_s »
For some unknown reason to me after the last good DVD I burned my Optic Drive which both CD/DVD burning capabilities now says when you look at the properties says its a CD drive. And as far as I know my external drive F: is also both but it will not burn there either. I am about to try with a different project in case so test if it happens to be the file did not convert properly the last time. Wish me luck. I will post if I was successful or not.
robertg_s
Post by robertg_s »
Hello all
You don't have to the me any suggestions. I tried another project and it worked. So then I redid the one I had the problem with after that and it too worked so must of been something I was doing at the same time that made it not work the first time.
Hope you all have a great day.
Robert
