I have created a menu that uses a specific font.
Yesterday, I created 4 DVDs with the same menu style and they were all worked great.
Today when I opened the files from yesterday, the font was replaced by Tahoma everywhere in the menu, and for all 4 projects.
ConvertxtoDVD won't even load a font file now, and only shows default fonts in the drop menu. It also will not display the font folder in the Windows folder. If I manually enter the path, the software will not display any font files, even with a file type set to all.
I have 25 more projects to complete, I really do not need this grief right now.
Any useful information would be greatly appreciated.
- Snowowl -
ConvertxtoDVD 7 Has stopped loading Fonts
Re: ConvertxtoDVD 7 Has stopped loading Fonts
I have found a temporary solution.
I used to menu editor to access the menu page title.
The I imported the ttf file into the menu. I had to use another location (NOT c:\windows\fonts) to get ConvertXtoDVD 7 to see the font.
Once I did that, all the projects have the font back in place.
Hopefully the font will stick this way.
BTW all other apps in my Windows 10 environment had no problem using the existing font when ConvertXtoDVD 7 would not load it. Re-installing the font did not solve the issue for ConvertXtoDVD 7.
- Snowowl -
- Snowowl -
