Convertxtohd closing itself
gbasource
Post by gbasource »
I am using convertxtohd on windows 10 and it will get about halfway into converting a movie then the program will close itself. After checking the event viewer log, it says this:
Log Name: Application
Source: Application Error
Date: 21/04/2021 15:05:21
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: DESKTOP-OHCG891
Description:
Faulting application name: ConvertXToHD.exe, version: 1.3.0.43, time stamp: 0x567aba8f
Faulting module name: KERNELBASE.dll, version: 10.0.19041.906, time stamp: 0x26452a2a
Exception code: 0x0eedfade
Fault offset: 0x0012a6e2
Faulting process ID: 0x2b90
Faulting application start time: 0x01d736af99ce8106
Faulting application path: C:\Program Files (x86)\VSO\ConvertXtoHD\1\ConvertXToHD.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report ID: b47c4c4b-a584-4462-af4f-dd5e1199a36e
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>100</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2021-04-21T14:05:21.7251249Z" />
<EventRecordID>12934</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer>DESKTOP-OHCG891</Computer>
<Security />
</System>
<EventData>
<Data>ConvertXToHD.exe</Data>
<Data>1.3.0.43</Data>
<Data>567aba8f</Data>
<Data>KERNELBASE.dll</Data>
<Data>10.0.19041.906</Data>
<Data>26452a2a</Data>
<Data>0eedfade</Data>
<Data>0012a6e2</Data>
<Data>2b90</Data>
<Data>01d736af99ce8106</Data>
<Data>C:\Program Files (x86)\VSO\ConvertXtoHD\1\ConvertXToHD.exe</Data>
<Data>C:\Windows\System32\KERNELBASE.dll</Data>
<Data>b47c4c4b-a584-4462-af4f-dd5e1199a36e</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
Re: Convertxtohd closing itself
Post conversion or error log please.
gbasource
Post by gbasource »
:crash_log='C:\ProgramData\VSO\ConvertXtoHD\1\Log\ConvertXtoHD 1_crashlog_.20210421.140956.064.log'
:library=false
:app_name=ConvertXToHD.exe
:app_version=1.3.0.43
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
15:05:21.081 Error Error while encoding BDMV file: 00001.m2ts
15:05:21.069 ------------ *****************************************File encoded successfully: 00001.m2ts******************************************
15:05:21.030 Info Menu encoding failed
15:04:58.952 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=30000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,me_method=5,me_range=16,bsf=h264_mp4toannexb,slices=4,refs=3,bf=3,bufsize=25000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,keyint_min=24,pix_fmt=yuv420p
15:04:33.671 Info "ROOT" menu built successfully
15:02:38.823 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=30000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,me_method=5,me_range=16,bsf=h264_mp4toannexb,slices=4,refs=3,bf=3,bufsize=25000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,keyint_min=24,pix_fmt=yuv420p
15:02:34.534 Info Building ROOT & CHAPTERS, menus using template: VSO glossy template, blue background, up to 6 episodes/titles per page
15:02:34.336 Info video #1 - Processed video frames: 34529 (34528 frames encoded, 0 frames dropped, 0 frames duplicated)
14:22:45.645 Info H264 settings for stream #1: preset=superfast,qmin=2,lmin=236,mblmin=236,b=11300000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,me_range=16,bsf=h264_mp4toannexb,keyint_min=24,threads=3
14:22:45.636 ------------ +--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [English]]
+-[audio [eng] aac main audio 2 Ch., 48000 Hz, 4000 Kbps]
+--> [video #1 - h264 video, 1920x1080, yuv420p, 16x9, 23.98Fps, 11300 Kbps]
+-[video hevc 1920x1080 16:9 yuv420p, 23.98 fps, 0 Kbps]
Output file: C:\Users\scott\Desktop\Converted Blurays\One Piece The Skypiea Saga (5th Voyage)\BDMV\STREAM\00001.m2ts (Blu-ray)
Input file: C:\Users\scott\Documents\VUZEDO~1\_ANIME~1\ON5FEB~1\[AnimeRG] One Piece - 197 [1080p] [Dual-Audio] [Multi-Sub] [x265] [pseudo].mkv
Video filters used:
- DeInterlace filter: FFmpeg (used only if needed)
- Upscale filter: linear (vso), Downscale filter: linear (vso). Fit method: stretch (Padding: top: 0, bottom: 0, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
14:22:45.576 Info Chapters to generate: 5
14:22:42.569 Info Added in conversion queue list...
14:22:42.427 Group ******************** Titleset #2 - ~24 min. File: "Episode 197" -> 00001.m2ts - Blu-ray ********************|GK_TITLESET|
15:02:56.435 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=30000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,me_method=5,me_range=16,bsf=h264_mp4toannexb,slices=4,refs=3,bf=3,bufsize=25000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,keyint_min=24,pix_fmt=yuv420p
15:02:25.949 Info "ROOT" menu built successfully
15:00:17.070 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=30000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,me_method=5,me_range=16,bsf=h264_mp4toannexb,slices=4,refs=3,bf=3,bufsize=25000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,keyint_min=24,pix_fmt=yuv420p
15:00:13.485 Info Building ROOT & CHAPTERS, menus using template: VSO glossy template, blue background, up to 6 episodes/titles per page
15:00:13.159 Info video #1 - Processed video frames: 34529 (34528 frames encoded, 0 frames dropped, 0 frames duplicated)
14:22:45.577 Info H264 settings for stream #1: preset=superfast,qmin=2,lmin=236,mblmin=236,b=11300000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,me_range=16,bsf=h264_mp4toannexb,keyint_min=24,threads=3
14:22:45.561 ------------ +--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [English]]
Output file: C:\Users\scott\Desktop\Converted Blurays\One Piece The Skypiea Saga (5th Voyage)\BDMV\STREAM\00000.m2ts (Blu-ray)
Input file: C:\Users\scott\Documents\VUZEDO~1\_ANIME~1\ON5FEB~1\[AnimeRG] One Piece - 196 [1080p] [Dual-Audio] [Multi-Sub] [x265] [pseudo].mkv
Video filters used:
14:22:45.548 Info Chapters to generate: 5
14:22:42.302 Info Added in conversion queue list...
14:22:42.164 Group ******************** Titleset #1 - ~24 min. File: "Episode 196" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
14:22:42.153 Info Encoding options: Medium Project (Automatic)
14:22:42.150 Info Target size: 22.5 GB.
14:22:40.440 Info Don't log FFMpeg log events
14:22:40.436 ------------ ***************************************************Burn settings end****************************************************
14:22:40.433 Info Default speed selected: 4x
14:22:40.430 Info [ ] Delete vsomsl files after burn complete
14:22:40.427 Info [ ] Delete output folder after burn complete
14:22:40.424 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
14:22:40.421 Info SAO setting: Automatic
14:22:40.418 Info [x] Burn result to disk / as ISO file in working folder
14:22:40.415 ------------ **************************************************Burn settings begin***************************************************
14:22:40.415 Group Encoding session started at 14:22:40: 10 titleset(s) to encode|GK_CONVERT_SESSION|
14:12:02.755 Info #1 hevc 1920x1080 16:9 yuv420p, 23.98 fps, 0 Kbps
14:12:02.722 Group Video streams
14:12:02.750 Info #2 [eng] aac main audio 2 Ch., 48000 Hz, 4000 Kbps - English
14:12:02.745 Info #3 [jpn] aac main audio 2 Ch., 44100 Hz, 4000 Kbps - Japanese
14:12:02.722 Group Audio streams
14:12:02.741 Info #4 [eng] 0:0:3 - ass 720x576 - English
14:12:02.736 Info #5 [ara] 0:0:4 - subrip 720x576 - Arabic
14:12:02.732 Info #6 [por] 0:0:5 - subrip 720x576 - Brazilian
14:12:02.727 Info #7 [spa] 0:0:6 - subrip 720x576 - Spanish
14:12:02.722 Group Subtitle streams
14:12:02.722 Warning DISCARDED #8 -
14:12:02.722 Group Discarded streams
14:12:02.722 Group Added file: C:\Users\scott\Documents\VUZEDO~1\_ANIME~1\ON5FEB~1\[AnimeRG] One Piece - 205 [1080p] [Dual-Audio] [Multi-Sub] [x265] [pseudo].mkv
14:11:59.971 Info #1 hevc 1920x1080 16:9 yuv420p, 23.98 fps, 0 Kbps
14:11:59.925 Group Video streams
14:11:59.964 Info #2 [eng] aac main audio 2 Ch., 48000 Hz, 4000 Kbps - English
14:11:59.960 Info #3 [jpn] aac main audio 2 Ch., 44100 Hz, 4000 Kbps - Japanese
14:11:59.925 Group Audio streams
14:11:59.956 Info #4 [eng] 0:0:3 - ass 720x576 - English
14:11:59.950 Info #5 [ara] 0:0:4 - subrip 720x576 - Arabic
14:11:59.941 Info #6 [por] 0:0:5 - subrip 720x576 - Brazilian
14:11:59.932 Info #7 [spa] 0:0:6 - subrip 720x576 - Spanish
14:11:59.925 Group Subtitle streams
14:11:59.925 Warning DISCARDED #8 -
14:11:59.925 Group Discarded streams
14:11:59.925 Group Added file: C:\Users\scott\Documents\VUZEDO~1\_ANIME~1\ON5FEB~1\[AnimeRG] One Piece - 204 [1080p] [Dual-Audio] [Multi-Sub] [x265] [pseudo].mkv
14:11:13.345 Info #1 hevc 1920x1080 16:9 yuv420p, 23.98 fps, 0 Kbps
14:11:13.318 Group Video streams
14:11:13.340 Info #2 [eng] aac main audio 2 Ch., 48000 Hz, 4000 Kbps - English
14:11:13.335 Info #3 [jpn] aac main audio 2 Ch., 44100 Hz, 4000 Kbps - Japanese
14:11:13.318 Group Audio streams
14:11:13.332 Info #4 [eng] 0:0:3 - ass 720x576 - English
14:11:13.329 Info #5 [ara] 0:0:4 - subrip 720x576 - Arabic
14:11:13.325 Info #6 [por] 0:0:5 - subrip 720x576 - Brazilian
14:11:13.322 Info #7 [spa] 0:0:6 - subrip 720x576 - Spanish
14:11:13.318 Group Subtitle streams
14:11:13.318 Warning DISCARDED #8 -
14:11:13.318 Group Discarded streams
14:11:13.318 Group Added file: C:\Users\scott\Documents\VUZEDO~1\_ANIME~1\ON5FEB~1\[AnimeRG] One Piece - 203 [1080p] [Dual-Audio] [Multi-Sub] [x265] [pseudo].mkv
14:11:10.923 Info #1 hevc 1920x1080 16:9 yuv420p, 23.98 fps, 0 Kbps
14:11:10.903 Group Video streams
14:11:10.921 Info #2 [eng] aac main audio 2 Ch., 48000 Hz, 4000 Kbps - English
14:11:10.918 Info #3 [jpn] aac main audio 2 Ch., 44100 Hz, 4000 Kbps - Japanese
14:11:10.903 Group Audio streams
14:11:10.915 Info #4 [eng] 0:0:3 - ass 720x576 - English
14:11:10.913 Info #5 [ara] 0:0:4 - subrip 720x576 - Arabic
14:11:10.909 Info #6 [por] 0:0:5 - subrip 720x576 - Brazilian
14:11:10.906 Info #7 [spa] 0:0:6 - subrip 720x576 - Spanish
14:11:10.903 Group Subtitle streams
14:11:10.903 Warning DISCARDED #8 -
14:11:10.903 Group Discarded streams
14:11:10.903 Group Added file: C:\Users\scott\Documents\VUZEDO~1\_ANIME~1\ON5FEB~1\[AnimeRG] One Piece - 202 [1080p] [Dual-Audio] [Multi-Sub] [x265] [pseudo].mkv
14:11:08.682 Info #1 hevc 1920x1080 16:9 yuv420p, 23.98 fps, 0 Kbps
14:11:08.665 Group Video streams
14:11:08.680 Info #2 [eng] aac main audio 2 Ch., 48000 Hz, 4000 Kbps - English
14:11:08.678 Info #3 [jpn] aac main audio 2 Ch., 44100 Hz, 4000 Kbps - Japanese
14:11:08.665 Group Audio streams
14:11:08.676 Info #4 [eng] 0:0:3 - ass 720x576 - English
14:11:08.674 Info #5 [ara] 0:0:4 - subrip 720x576 - Arabic
14:11:08.671 Info #6 [por] 0:0:5 - subrip 720x576 - Brazilian
14:11:08.668 Info #7 [spa] 0:0:6 - subrip 720x576 - Spanish
14:11:08.665 Group Subtitle streams
14:11:08.665 Warning DISCARDED #8 -
14:11:08.665 Group Discarded streams
14:11:08.665 Group Added file: C:\Users\scott\Documents\VUZEDO~1\_ANIME~1\ON5FEB~1\[AnimeRG] One Piece - 201 [1080p] [Dual-Audio] [Multi-Sub] [x265] [pseudo].mkv
14:11:06.556 Info #1 hevc 1920x1080 16:9 yuv420p, 23.98 fps, 0 Kbps
14:11:06.542 Group Video streams
14:11:06.555 Info #2 [eng] aac main audio 2 Ch., 48000 Hz, 4000 Kbps - English
14:11:06.553 Info #3 [jpn] aac main audio 2 Ch., 44100 Hz, 4000 Kbps - Japanese
14:11:06.542 Group Audio streams
14:11:06.550 Info #4 [eng] 0:0:3 - ass 720x576 - English
14:11:06.548 Info #5 [ara] 0:0:4 - subrip 720x576 - Arabic
14:11:06.546 Info #6 [por] 0:0:5 - subrip 720x576 - Brazilian
14:11:06.544 Info #7 [spa] 0:0:6 - subrip 720x576 - Spanish
14:11:06.542 Group Subtitle streams
14:11:06.542 Warning DISCARDED #8 -
14:11:06.542 Group Discarded streams
14:11:06.542 Group Added file: C:\Users\scott\Documents\VUZEDO~1\_ANIME~1\ON5FEB~1\[AnimeRG] One Piece - 200 [1080p] [Dual-Audio] [Multi-Sub] [x265] [pseudo].mkv
14:11:04.766 Info #1 hevc 1920x1080 16:9 yuv420p, 23.98 fps, 0 Kbps
14:11:04.748 Group Video streams
14:11:04.763 Info #2 [eng] aac main audio 2 Ch., 48000 Hz, 4000 Kbps - English
14:11:04.761 Info #3 [jpn] aac main audio 2 Ch., 44100 Hz, 4000 Kbps - Japanese
14:11:04.748 Group Audio streams
14:11:04.758 Info #4 [eng] 0:0:3 - ass 720x576 - English
14:11:04.756 Info #5 [ara] 0:0:4 - subrip 720x576 - Arabic
14:11:04.753 Info #6 [por] 0:0:5 - subrip 720x576 - Brazilian
14:11:04.751 Info #7 [spa] 0:0:6 - subrip 720x576 - Spanish
14:11:04.748 Group Subtitle streams
14:11:04.748 Warning DISCARDED #8 -
14:11:04.748 Group Discarded streams
14:11:04.748 Group Added file: C:\Users\scott\Documents\VUZEDO~1\_ANIME~1\ON5FEB~1\[AnimeRG] One Piece - 199 [1080p] [Dual-Audio] [Multi-Sub] [x265] [pseudo].mkv
14:11:03.285 Info #1 hevc 1920x1080 16:9 yuv420p, 23.98 fps, 0 Kbps
14:11:03.274 Group Video streams
14:11:03.283 Info #2 [eng] aac main audio 2 Ch., 48000 Hz, 4000 Kbps - English
14:11:03.282 Info #3 [jpn] aac main audio 2 Ch., 44100 Hz, 4000 Kbps - Japanese
14:11:03.274 Group Audio streams
14:11:03.280 Info #4 [eng] 0:0:3 - ass 720x576 - English
14:11:03.279 Info #5 [ara] 0:0:4 - subrip 720x576 - Arabic
14:11:03.277 Info #6 [por] 0:0:5 - subrip 720x576 - Brazilian
14:11:03.276 Info #7 [spa] 0:0:6 - subrip 720x576 - Spanish
14:11:03.274 Group Subtitle streams
14:11:03.274 Warning DISCARDED #8 -
14:11:03.274 Group Discarded streams
14:11:03.274 Group Added file: C:\Users\scott\Documents\VUZEDO~1\_ANIME~1\ON5FEB~1\[AnimeRG] One Piece - 198 [1080p] [Dual-Audio] [Multi-Sub] [x265] [pseudo].mkv
14:11:01.703 Info #1 hevc 1920x1080 16:9 yuv420p, 23.98 fps, 0 Kbps
14:11:01.695 Group Video streams
14:11:01.701 Info #2 [eng] aac main audio 2 Ch., 48000 Hz, 4000 Kbps - English
14:11:01.700 Info #3 [jpn] aac main audio 2 Ch., 44100 Hz, 4000 Kbps - Japanese
14:11:01.695 Group Audio streams
14:11:01.699 Info #4 [eng] 0:0:3 - ass 720x576 - English
14:11:01.698 Info #5 [ara] 0:0:4 - subrip 720x576 - Arabic
14:11:01.697 Info #6 [por] 0:0:5 - subrip 720x576 - Brazilian
14:11:01.696 Info #7 [spa] 0:0:6 - subrip 720x576 - Spanish
14:11:01.695 Group Subtitle streams
14:11:01.695 Warning DISCARDED #8 -
14:11:01.695 Group Discarded streams
14:11:01.695 Group Added file: C:\Users\scott\Documents\VUZEDO~1\_ANIME~1\ON5FEB~1\[AnimeRG] One Piece - 197 [1080p] [Dual-Audio] [Multi-Sub] [x265] [pseudo].mkv
14:10:55.763 Info #1 hevc 1920x1080 16:9 yuv420p, 23.98 fps, 0 Kbps
14:10:55.758 Group Video streams
14:10:55.762 Info #2 [eng] aac main audio 2 Ch., 48000 Hz, 4000 Kbps - English
14:10:55.762 Info #3 [jpn] aac main audio 2 Ch., 44100 Hz, 4000 Kbps - Japanese
14:10:55.758 Group Audio streams
14:10:55.761 Info #4 [eng] 0:0:3 - ass 720x576 - English
14:10:55.761 Info #5 [ara] 0:0:4 - subrip 720x576 - Arabic
14:10:55.760 Info #6 [por] 0:0:5 - subrip 720x576 - Brazilian
14:10:55.759 Info #7 [spa] 0:0:6 - subrip 720x576 - Spanish
14:10:55.758 Group Subtitle streams
14:10:55.758 Warning DISCARDED #8 -
14:10:55.758 Group Discarded streams
14:10:55.758 Group Added file: C:\Users\scott\Documents\VUZEDO~1\_ANIME~1\ON5FEB~1\[AnimeRG] One Piece - 196 [1080p] [Dual-Audio] [Multi-Sub] [x265] [pseudo].mkv
14:10:07.287 Info Menu templates loaded: 35
14:10:05.456 Info Total Physical Memory : 20022 Mb.
Available Physical Memory : 16993 Mb.
Memory Load : 15%
Available Virtual Memory : 3627 Mb.
Total Memory : 23420 Mb.
Available Memory : 20132 Mb.
14:10:05.456 Info Processor AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx with 8 core(s) CPU
Supported instruction set: MMX,ExMMX,sse,sse2 (slow),sse3,sse41,sse42,sse4A,avx,avx2,bmi1,bmi2,aes
14:10:05.454 Info User OS: Microsoft Windows XP, Microsoft Windows XP Home Edition (Build 2600: Service Pack 3)
file name : C:\Program Files (x86)\VSO\ConvertXtoHD\1\ConvertXToHD.exe
file version : 1.3.0.43
User language : English (United Kingdom)
System language : English (United Kingdom)
14:09:57.567 Error Failed to update template vsoglossy_green_10ch.ini
14:09:57.567 Group Errors when tryng to update templates
14:09:56.144 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\1\templates"
14:09:56.136 ------------ **************************ConvertXToHD.exe:11152 Log session start 2021-04-21 at 14:09:49.764***************************
14:09:56.119 Info 1 writer(s) found.
14:09:56.058 Group Burn engine events
Memory Load : 15%
You have really odd setup.
Win XP Home can't use more than 4GB RAM but you have 22GB according to log.
Anyway, Win XP is not supported anymore so there is no guarantee that any modern program runs on it.
