Need Subtitles Disabled
RicRey
Post by RicRey »
I can disable subtitles in my VLC Player, so I know they're not part of the video. And I've fiddled with the settings, but get no where. When I go to preview a video before committing to burning a disc, it shows subtitles no matter what. It seems to be a problem with any anime I try making a disc of.
bach4816
Re: Need Subtitles Disabled
Post by bach4816 »
depending on where you are getting the video files, some people post files to web sites with subtitles burned into them and they can't be removed. Most subtitles are a separate file. Thus when you get a video file, watch the video prior to burning to see if it plays and has subtitles burned into it. If it does look for another one!!!
go to this screen to fix this i.e. subs do not automatically appear when play dvd
I believe the software default is to Always display a subtitle track on playback. So, that option is probably checked. Try unchecking that option. I know I have to uncheck it when configuration a new installation of CXD.
ernie1022
Post by ernie1022 »
yoyo57 wrote: Fri Apr 30, 2021 10:21 pm go to this screen to fix this i.e. subs do not automatically appear when play dvd
Sorry, but that doesn't work!
If that does not work, can only suggest do a "clean" install, and then turn off subs as described in the previous image.
As something wrong with your config that a clean install may fix. The actions in the image work for me.
Some players have option to turn subtitles on/off or even showing only certain language subtitles.
