resolution
oterski
resolution
Post by oterski »
I downloaded the convertxtodvd 7 for a trial,and it worked great.My only problem was the resolution of the dvd I burned was not the best.I noticed the only frame size I could use was the 720x480.If I purchase the software,is there a higher resolution or frame size option?Such as 1440x1080 etc.And if I use a higher one will the picture be better?Thank you.
paul
Re: resolution
From my understanding the industry dvd standards for resolution are 720×480 pixels for NTSC, and 720×576 pixels for PAL.
I use VSO ConvertxtoHD 3, for the higher resolutions and either burn to Blu-Ray disks or AVCHD to DVD5 disks
Re: resolution
As far as I know, that's the highest resolution you're going to get for DVD.
