Why So Slow
Skeeter
Why So Slow
Post by Skeeter »
I'm using vs. 7.0.64.
It took an hour to convert and 45 minutes to burn a 2 hour video.
Can anyone tell me why so slow? Thanks!
Re: Why So Slow
Conversion logs are needed to give answers. Without them it is just a guessing game.
Re: Why So Slow
For me it depends on the PC s hardware, if I use an old Core2 Duo to convert say 3 videos totaling 5 hours of content to a DVD5 disk, can take 6 hours. On my newer i9 with 3080 video card, the time drops to around 1 hour. And this is using max quality options.
For me the conversion time is very good
Skeeter
Re: Why So Slow
Post by Skeeter »
I got to thinking....what have I done differently?
I think it's that I bought a new 4 port hub. My DVD burner doesn't like it.
I plugged my DVD burner directly into my laptop and it worked great.
My computer is a quad core only 3 months old.
The new hub is 3.0.
Wonder why it wouldn't work on there?
Anyway, if anything changes I post a log file.
Thank you both so much for your time.
Re: Why So Slow
USB hub causes loss of power and possible data confliction slowing speed.
Those should only be used for keyboards, mouse etc.
Re: Why So Slow
DVD writers and external hard drives should always be connected directly to the motherboard for best results.
