create a title or menu title without chapters
Ricardito2
Post by Ricardito2 »
I want to convert some video clips and create a title or menu title without chapters that appears at the beginning and then the clips start. I haven't figured out how to do this. I will thank anyone who can help me.
Re: ConvertXtoDVD 7
First, import a video file for a Title. In the right hand pane of information, there's a tab on the bottom that has a stopwatch on it. This is the Chapters tab. Press the Clear all chapters button. That should do what you want if I understand your request correctly.
Unless you meant you want a DVD that starts immediately playing Titles without a menu?
