[h265 not supported] Conversion Failed
mirkoianni4791
Post by mirkoianni4791 »
I can't do the conversion
What could be the problem?
Log File:
:std_log='C:\Users\Mirko\AppData\Roaming\VSO\ConvertXtoHD\3\Log\ConvertXtoHD 3_mainlog.20211003.214551.930.log'
:library=false
:app_name=ConvertXToHD.exe
:app_version=3.0.0.74
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
12:50:19.170 Warning folder "
10:43:13.429 Info Conversion failed after 01:37:15
09:05:57.433 Info [ ] Loop playback
09:05:57.430 Info [ ] Play titles one after the other
09:05:57.428 Info [ ] Don't create title menu for single video
09:05:57.426 Info [x] Return to title menu after titleset playback
09:05:57.424 Info [ ] Skip root menu initially
09:05:57.421 Info [ ] Auto-start playback
09:05:57.419 Info Template: 10 titles per page without sub menus (open style), contains 1 page(s)
09:05:57.419 Group Blu-ray/AVCHD menu options
09:05:57.417 Info Output target size : BD-25 (23000 MB)
09:05:57.414 Info Number of core(s) used for encoding : 20
09:05:57.412 Info Number of core(s) used for decoding : 20
09:05:57.410 Info [ ] Use 2 pass encoding
09:05:57.407 Info [x] Use best video quality settings
09:05:57.405 Info [x] Use hardware encoding (if possible)
09:05:57.403 Info [x] Use hardware decoding (if possible)
09:05:57.400 Info Max simultaneous conversions: 2
09:05:57.400 Group Opzioni avanzate codifica
10:43:07.454 Error Error while encoding file: av Violation d'accès à l'adresse 0088E608 dans le module 'ConvertXToHD.exe'. Lecture de l'adresse 8AEB0004
10:12:51.097 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=118,mblmin=118,b=16000000,bt=50M,maxrate=40000000,minrate=0,me_method=x1,codec=h264_nvenc,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,threads=20
10:12:51.094 ------------ +--> [subtitle #6 - hdmv_pgs_subtitle subtitle, 1920x1080 [English]]
+-[subtitle #5 - subrip subtitle]
+--> [subtitle #5 - hdmv_pgs_subtitle subtitle, 1920x1080 [Italian]]
+-[subtitle #4 - subrip subtitle]
+--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 [Italian] (Default)]
+-[subtitle #3 - subrip subtitle]
+--> [audio #3 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [English]]
+-[audio [eng] eac3 audio principale 6 can. 48000Hz , 256 Kbps]
+--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [Italian]]
+-[audio [ita] ac3 audio principale 6 can. 48000Hz , 640 Kbps]
+--> [video #1 - h264_nvenc video, 1920x1080, yuv420p, 16x9, 23,98Fps, 16000Kbps]
+-[video hevc 3840x2160 16:9 yuv420p10le, 23,98Fps, 0Kbps ]
File destinazione: C:\Users\Mirko\Desktop\AHS CULT\BDMV\STREAM\00002.m2ts (Blu-ray)
File sorgente: F:\AMERICAN HORROR STORY\Stagione 7 - Cult -\American.Horror.Story.Cult.07x03.Vicini.Infernali.ITA.ENG.2160p.HULU.WEB-DL.DDP5.1.H.265-Mirkoianni.mkv
Video filters used:
- DeInterlace filter: VSO
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: automatic (Padding: top: 0, bottom: 0, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
10:12:51.091 Info Chapters to generate: 7 (0h00m00s, 0h05m30s, 0h18m25s, 0h28m25s, 0h35m57s, 0h42m43s, 0h42m48s, )
10:12:51.089 Important Starting video encoding: [Memory load 32%] [Available virtual memory 1559 Mb.]
10:12:50.811 Verbose FFmpeg Opening file F:\AMERICAN HORROR STORY\Stagione 7 - Cult -\American.Horror.Story.Cult.07x03.Vicini.Infernali.ITA.ENG.2160p.HULU.WEB-DL.DDP5.1.H.265-Mirkoianni.mkv
09:05:57.329 Verbose FFmpeg Opening file F:\AMERICAN HORROR STORY\Stagione 7 - Cult -\American.Horror.Story.Cult.07x03.Vicini.Infernali.ITA.ENG.2160p.HULU.WEB-DL.DDP5.1.H.265-Mirkoianni.mkv
09:05:57.328 Group ******************** Set titoli #3 - ~43 min. file: "3: VICINI INFERNALI" -> 00002.m2ts - Blu-ray ********************|GK_TITLESET|
10:12:40.775 ------------ *****************************************File encoded successfully: 00001.m2ts******************************************
10:12:40.772 Important Starting BD root menu encoding: [Memory load 30%] [Available virtual memory 2136 Mb.]
10:12:40.770 Info Building menus using template: 10 titles per page without sub menus (open style)
10:12:40.749 Info subtitle #6 - Encoded subtitles frames: 1325
10:12:40.747 Info subtitle #5 - Encoded subtitles frames: 1203
10:12:40.744 Info subtitle #4 - Encoded subtitles frames: 15
10:12:40.742 Info video #1 - Processed video frames: 67437 (67437 frames encoded, 0 frames dropped, 0 frames duplicated)
10:12:40.676 Error 48 subtitle frames can't be encoded. Subtitles may not be complete. You should consider integrating subtitles directly to the video stream for perfect rendering
09:39:48.170 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=118,mblmin=118,b=16000000,bt=50M,maxrate=40000000,minrate=0,me_method=x1,codec=h264_nvenc,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,threads=20
09:39:48.167 ------------ +--> [subtitle #6 - hdmv_pgs_subtitle subtitle, 1920x1080 [English]]
File destinazione: C:\Users\Mirko\Desktop\AHS CULT\BDMV\STREAM\00001.m2ts (Blu-ray)
File sorgente: F:\AMERICAN HORROR STORY\Stagione 7 - Cult -\American.Horror.Story.Cult.07x02.Non.Avere.Paura.Del.Buio.ITA.ENG.2160p.HULU.WEB-DL.DDP5.1.H.265-Mirkoianni.mkv
Video filters used:
09:39:48.164 Info Chapters to generate: 7 (0h00m00s, 0h07m05s, 0h17m13s, 0h23m04s, 0h39m14s, 0h46m05s, 0h46m11s, )
09:39:48.162 Important Starting video encoding: [Memory load 32%] [Available virtual memory 1588 Mb.]
09:39:47.905 Verbose FFmpeg Opening file F:\AMERICAN HORROR STORY\Stagione 7 - Cult -\American.Horror.Story.Cult.07x02.Non.Avere.Paura.Del.Buio.ITA.ENG.2160p.HULU.WEB-DL.DDP5.1.H.265-Mirkoianni.mkv
09:05:57.287 Verbose FFmpeg Opening file F:\AMERICAN HORROR STORY\Stagione 7 - Cult -\American.Horror.Story.Cult.07x02.Non.Avere.Paura.Del.Buio.ITA.ENG.2160p.HULU.WEB-DL.DDP5.1.H.265-Mirkoianni.mkv
09:05:57.258 Group ******************** Set titoli #2 - ~46 min. file: "2: NON AVERE PAURA DEL BUIO" -> 00001.m2ts - Blu-ray ********************|GK_TITLESET|
09:39:37.770 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
09:39:37.767 Important Starting BD root menu encoding: [Memory load 31%] [Available virtual memory 2165 Mb.]
09:39:37.765 Info Building menus using template: 10 titles per page without sub menus (open style)
09:39:37.745 Info subtitle #6 - Encoded subtitles frames: 1446
09:39:37.742 Info subtitle #5 - Encoded subtitles frames: 1367
09:39:37.740 Info subtitle #4 - Encoded subtitles frames: 111
09:39:37.738 Info video #1 - Processed video frames: 70095 (70095 frames encoded, 0 frames dropped, 0 frames duplicated)
09:39:37.672 Error 35 subtitle frames can't be encoded. Subtitles may not be complete. You should consider integrating subtitles directly to the video stream for perfect rendering
09:05:57.722 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=118,mblmin=118,b=16000000,bt=50M,maxrate=40000000,minrate=0,me_method=x1,codec=h264_nvenc,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,threads=20
09:05:57.719 ------------ +--> [subtitle #6 - hdmv_pgs_subtitle subtitle, 1920x1080 [English]]
File destinazione: C:\Users\Mirko\Desktop\AHS CULT\BDMV\STREAM\00000.m2ts (Blu-ray)
File sorgente: F:\AMERICAN HORROR STORY\Stagione 7 - Cult -\American.Horror.Story.Cult.07x01.La.Notte.Delle.Elezioni.ITA.ENG.2160p.HULU.WEB-DL.DDP5.1.H.265-Mirkoianni.mkv
Video filters used:
09:05:57.716 Info Chapters to generate: 7 (0h00m00s, 0h08m23s, 0h25m39s, 0h34m08s, 0h42m33s, 0h47m58s, 0h48m02s, )
09:05:57.714 Important Starting video encoding: [Memory load 32%] [Available virtual memory 1539 Mb.]
09:05:57.442 Verbose FFmpeg Opening file F:\AMERICAN HORROR STORY\Stagione 7 - Cult -\American.Horror.Story.Cult.07x01.La.Notte.Delle.Elezioni.ITA.ENG.2160p.HULU.WEB-DL.DDP5.1.H.265-Mirkoianni.mkv
09:05:57.195 Verbose FFmpeg Opening file F:\AMERICAN HORROR STORY\Stagione 7 - Cult -\American.Horror.Story.Cult.07x01.La.Notte.Delle.Elezioni.ITA.ENG.2160p.HULU.WEB-DL.DDP5.1.H.265-Mirkoianni.mkv
09:05:56.656 Group ******************** Set titoli #1 - ~48 min. file: "1: LA NOTTE DELLE ELEZIONI" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
09:05:56.652 Info Encoding options: Very short Project (Automatic)
09:05:56.650 Info Target size: 23000 Mb.
09:05:56.639 Important Setting queuer for Blu-ray output: [Wait: 4000], [ld: 1000], [Hd: 10000], [MAM: 600], [RM: 500], [ALL: True]
09:05:56.637 Info Non memorizzare gli eventi FFMpeg nel registro
09:05:56.635 ------------ ***************************************************Burn settings end****************************************************
09:05:56.632 Info Default speed selected: 4x
09:05:56.630 Info [x] Delete vsomsl files after burn complete
09:05:56.628 Info [x] Delete output folder after burn complete
09:05:56.626 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
09:05:56.624 Info SAO setting: Automatic
09:05:56.621 Info [x] Burn result to disk / as ISO file in working folder
09:05:56.619 ------------ **************************************************Burn settings begin***************************************************
09:05:56.619 Group Codifica sessione avviata a 09:05:56: 3 set titoli da codificare -> Failed after 01:37:15|GK_CONVERT_SESSION|
09:05:09.585 Important Closing editor
09:05:08.739 Info changed Auto_add_period "NAN" -> "NAN"
09:05:08.738 Group Set titoli "3: VICINI INFERNALI"
09:05:08.736 Info changed Auto_add_period "NAN" -> "NAN"
09:05:08.735 Group Set titoli "2: NON AVERE PAURA DEL BUIO"
09:05:08.733 Info changed Auto_add_period "NAN" -> "NAN"
09:05:08.732 Group Set titoli "1: LA NOTTE DELLE ELEZIONI"
09:05:08.730 Info Nessun capitolo rilevato
09:05:08.730 Group Stili testo
09:05:08.730 Group Scatti progetto
09:05:08.728 Info changed audio_max_peak "NAN" -> "NAN"
09:05:08.728 Group Progetto principale
09:05:08.726 Important ==> 1 avviso(i) e 0 suggerimento(i), il menu è corretto
09:05:08.724 Important Warning: button for Play all non verrà visualizzato
09:05:08.685 Group **** Verifica consistenza menu ****
09:05:04.301 Info Initialized Titolo 3: VICINI INFERNALI
09:05:04.298 Info Initialized Titolo 2: NON AVERE PAURA DEL BUIO
09:05:04.296 Info Initialized Titolo 1: LA NOTTE DELLE ELEZIONI
09:05:04.294 Info Menu template used "C:\ProgramData\VSO\ConvertXtoHD\3\Templates\Open Style\10_TitlesPerPageNoRoot.ini"
09:05:04.261 Info Menu editor mode
09:05:04.258 Important Initialising editor
09:05:04.258 Group Eventi modifica menu
09:05:01.603 Info Removed segment: 4: IO CREDO IN TE
09:04:58.757 Important Closing editor
09:04:57.909 Info changed Auto_add_period "NAN" -> "NAN"
09:04:57.907 Info [Location: Pulsante "Riproduci titolo"][param: 3][value: ][text value: 4: IO CREDO IN TE][Style: ][test style: (PageStyle)MNUS_TITLE(PageStyle)(GfxType)GT_TEXT(GfxType)(GfxLoc)ML_PLAY_EPISODE,(GfxLoc){DescTag}Captions in title menu pages{DescTag}][Scale X, Y: 2,67, 1,88: changed text_BlockTop "305" -> "260"
09:04:57.905 Info [Location: Pulsante "Riproduci titolo"][param: 3][value: ][text value: 4: IO CREDO IN TE][Style: ][test style: (PageStyle)MNUS_TITLE(PageStyle)(GfxType)GT_TEXT(GfxType)(GfxLoc)ML_PLAY_EPISODE,(GfxLoc){DescTag}Captions in title menu pages{DescTag}][Scale X, Y: 2,67, 1,88: changed text_BlockLeft "542" -> "283"
09:04:57.904 Group Set titoli "4: IO CREDO IN TE"
09:04:57.902 Info changed Auto_add_period "NAN" -> "NAN"
09:04:57.900 Info [Location: Pulsante "Riproduci titolo"][param: 2][value: ][text value: 3: VICINI INFERNALI][Style: ][test style: (PageStyle)MNUS_TITLE(PageStyle)(GfxType)GT_TEXT(GfxType)(GfxLoc)ML_PLAY_EPISODE,(GfxLoc){DescTag}Captions in title menu pages{DescTag}][Scale X, Y: 2,67, 1,88: changed text_BlockHeight "122" -> "247"
09:04:57.898 Info [Location: Pulsante "Riproduci titolo"][param: 2][value: ][text value: 3: VICINI INFERNALI][Style: ][test style: (PageStyle)MNUS_TITLE(PageStyle)(GfxType)GT_TEXT(GfxType)(GfxLoc)ML_PLAY_EPISODE,(GfxLoc){DescTag}Captions in title menu pages{DescTag}][Scale X, Y: 2,67, 1,88: changed text_BlockLeft "542" -> "541"
09:04:57.896 Info [Location: Pulsante "Riproduci titolo"][param: 2][value: ][text value: 3: VICINI INFERNALI][Style: ][test style: (PageStyle)MNUS_TITLE(PageStyle)(GfxType)GT_TEXT(GfxType)(GfxLoc)ML_PLAY_EPISODE,(GfxLoc){DescTag}Captions in title menu pages{DescTag}][Scale X, Y: 2,67, 1,88: changed text_height "122" -> "247"
09:04:57.895 Group Set titoli "3: VICINI INFERNALI"
09:04:57.893 Info changed Auto_add_period "NAN" -> "NAN"
09:04:57.892 Group Set titoli "2: NON AVERE PAURA DEL BUIO"
09:04:57.890 Info changed Auto_add_period "NAN" -> "NAN"
09:04:57.889 Group Set titoli "1: LA NOTTE DELLE ELEZIONI"
09:04:57.887 Info Nessun capitolo rilevato
09:04:57.887 Group Stili testo
09:04:57.887 Group Scatti progetto
09:04:57.885 Info changed audio_max_peak "NAN" -> "NAN"
09:04:57.885 Group Progetto principale
09:04:57.883 Important ==> 1 avviso(i) e 0 suggerimento(i), il menu è corretto
09:04:57.881 Important Warning: button for Play all non verrà visualizzato
09:04:57.835 Group **** Verifica consistenza menu ****
09:04:35.940 Info Initialized Titolo 4: IO CREDO IN TE
09:04:35.938 Info Initialized Titolo 3: VICINI INFERNALI
09:04:35.936 Info Initialized Titolo 2: NON AVERE PAURA DEL BUIO
09:04:35.934 Info Initialized Titolo 1: LA NOTTE DELLE ELEZIONI
09:04:35.932 Info Menu template used "C:\ProgramData\VSO\ConvertXtoHD\3\Templates\Open Style\10_TitlesPerPageNoRoot.ini"
09:04:35.900 Info Menu editor mode
09:04:35.896 Important Initialising editor
09:04:35.896 Group Eventi modifica menu
09:00:13.809 Warning folder "
screamjojo
Re: Conversion Failed
Post by screamjojo »
I have the same error,
Did you find a solution ?
Friend1982
Post by Friend1982 »
with v3.0.0.74 I got the same error. Something has been changed with the folder detection/"creation" (error message folder ") since version update.
I use the previous v3.0.0.73 to avoid this problem.
Maybe it will help you.
screamjojo
Friend1982 wrote: Sun Dec 26, 2021 10:31 am Hello,
Thanks but I've trying with version v3.0.0.73 and I've the memory leak bug :cry:
My conversion is 12 files (1 Gb each) with custom series menu.
Always the same file in error.
Please developper team can you help me ? I really like this software
Edit : I did these actions without success :
Uninstall, reboot, Install => Fail
Without Menu : Fail
With administrator privilege => Fail
With another folder => Fail
With only the file who was in error => Fail
With version v3.0.0.71 => Fail at the end of the conversion of my 12 files with memory leak error but all file are encoded successfully
My log :
21:10:02.994 Warning folder "
21:10:02.269 Info Conversion cancelled after 00:08:07
21:01:54.808 Info [ ] Loop playback
21:01:54.807 Info [ ] Play titles one after the other
21:01:54.807 Info [ ] Don't create title menu for single video
21:01:54.806 Info [x] Return to title menu after titleset playback
21:01:54.805 Info [x] Skip root menu initially
21:01:54.805 Info [ ] Auto-start playback
21:01:54.804 Info Template: Series (TV episodes), contains 6 page(s)
21:01:54.804 Group Blu-ray/AVCHD menu options
21:01:54.803 Info Output target size : BD-25 (23000 MB)
21:01:54.803 Info Number of core(s) used for encoding : 12
21:01:54.802 Info Number of core(s) used for decoding : 12
21:01:54.802 Info [ ] Use 2 pass encoding
21:01:54.801 Info [ ] Use best video quality settings
21:01:54.801 Info [x] Use hardware encoding (if possible)
21:01:54.800 Info [x] Use hardware decoding (if possible)
21:01:54.800 Info Max simultaneous conversions: 2
21:01:54.800 Group Options d'encodage avancées
21:10:00.377 Error Error while encoding file: av Violation d'accès à l'adresse 0088E608 dans le module 'ConvertXtoHD.exe'. Lecture de l'adresse 1AB40008
21:02:05.171 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=118,mblmin=118,b=16000000,bt=50M,maxrate=40000000,minrate=0,me_method=epzs,codec=h264_nvenc,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,threads=12
21:02:05.170 ------------ +--> [subtitle #6 - hdmv_pgs_subtitle subtitle, 1920x1080 [English]]
+--> [subtitle #5 - hdmv_pgs_subtitle subtitle, 1920x1080 [French]]
+--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 [French] (Default)]
+-[audio [eng] ac3 audio principale 6 Ch. 48000Hz , 448 Kbps]
+--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [French]]
+-[audio [fre] ac3 audio principale 6 Ch. 48000Hz , 448 Kbps]
+-[video dxva2 h264 1920x1080 16:9 dxva2_vld, 23,98Fps, 0Kbps ]
Fichier de sortie: F:\Mes documents\ConvertXtoHD\Dexter S01\BDMV\STREAM\00001.m2ts (Blu-ray)
Fichier source : F:\Mes documents\Downloads\Video\Dexter S01\Episode (2).mkv
Video filters used:
21:02:05.154 Info Chapters to generate: 6 (0h00m00s, 0h03m24s, 0h12m15s, 0h21m07s, 0h31m25s, 0h44m45s, )
21:02:05.153 Important Starting video encoding: [Memory load 23%] [Available virtual memory 2633 Mb.]
21:02:05.108 Info Décodage matériel : H.264 variable-length decoder, no film grain technology utilise Adapter #0 - NVIDIA GeForce RTX 3080, conversion de h264 vers yuv420p
21:02:05.057 Verbose FFmpeg Opening file F:\Mes documents\Downloads\Video\Dexter S01\Episode (2).mkv
21:01:54.441 Verbose FFmpeg Opening file F:\Mes documents\Downloads\Video\Dexter S01\Episode (2).mkv
21:01:54.440 Group ******************** Titre No 2 - ~54 min. Fichier : "Episode 2" -> 00001.m2ts - Blu-ray ********************|GK_TITLESET|
Thanks in advance
version 3.0.0.74 19/11/20 fixed the memory leak bug (in version 3.0.0.73) that caused crashes
screamjojo
yoyo57 wrote: Tue Dec 28, 2021 11:59 am version 3.0.0.74 19/11/20 fixed the memory leak bug (in version 3.0.0.73) that caused crashes
Yes but I've the same problem of @mirkoianni4791 , in version 3.0.0.74
screamjojo
Nobody can help me ?
The developers team no longer work on this software?
The developer team consists of 2 people now.
Right now VSO are working on VSO Downloader v6 (now in beta)
Rumours are, they will work on ConvterXtoVideo next, but let’s see what happens in 2022 ….
Anaïs
Re: [h265 not supported] Conversion Failed
Post by Anaïs »
h265 is not yet supported by ConvertXtoHD.
We're currently porting our video engine to a 64bit version that will fix this issue and remove all 32 bits limitations (support higher resolutions, bigger working buffers ...etc).
In the meantime, you can use this little tool to make your h265 videos compatible with ConvertXtoHD :)
https://www.vso-software.fr/download_pr ... 5converter
Hope it helps!
Anaïs,
VSO Support Team
johnmaxx
Post by johnmaxx »
Anaïs wrote: Tue Jun 28, 2022 3:09 pm Hi,
Hope it helps!
Does this tool affect the quality of h265 file? The ouput h264 file still has the same quality as the h265 file, doesn't it?
BucketofBolts
Post by BucketofBolts »
johnmaxx wrote: Mon Aug 08, 2022 3:27 pmDoes this tool affect the quality of h265 file? The ouput h264 file still has the same quality as the h265 file, doesn't it?
I was quite disappointed with the results of this tool from an H265 source - blocky and pixelated in my H264 result. It's apparently a "one-click" GUI which doesn't give one the opportunity to tweak parameters to try for a better result - however, since it calls FFMPEG one could theoretically tweak a config file somewhere (I didn't explore that) or manually pass to FFMPEG at command prompt with more exact/specific settings. Subtitle streams were stripped out (there are tools to get those and save and remux it back in). All in all, disappointing, and more disappointing that the flagship VSO product won't support H265 directly although I've seen the posts on this board, of course, about limited developers and devoting time to other products.
I've been using the free VSDC Video Editor for a few years on stubborn files ConvertXtoHD won't handle and exporting to H264 with it ("Ultra" quality) and got much better results on my test file vs the VSO "single-click" tool.
