DVD format to BluRay
dragnil
Post by dragnil »
Some years ago I recorded a concert from the TV to a DVD. A direct recording, no file saved to the PC.
I would like to incorporate the concert in a collection on BluRay disc using ConvertXtoHD; is this possible and how should I do it?
Thanks for any insight and help,
David
dragnil
Re: DVD format to BluRay
Post by dragnil »
I need to change the question!
As soon as I posted the one above I realised that I should try DVD Converter and, sure enough, there's an option to save as BD.I'll check my disc this evening but the files appear to be correct compared with my other BDs
So, my revised question is: C an I add this to a larger compilation consisting of performances in mp4 format downloaded from the web?
TIA
David
You should be able to load that one as title then add more from other sources.
dragnil
Post by dragnil »
Thanks, JJ, I'll give that a try.
I'm not an expert by any means, so thanks for your suggestion.
Unfortunately when I came to test the BD file I found the sound was out of synch quite badly, can you point me in the right direction to correct this please?
David
Is that audio off-sync constant or drifting?
It can be fixed, usually it is drifting if framerate has been changed.
