Hi, I wanted to ask to create my own buttons, is it possible?
is there any guide?
Create my own buttoms, it's possible?
Re: Create my own buttoms, it's possible?
If you go here and check a sample of the buttons you will surly manage to create your own.
It will take some time, patience and experimenting.
viewforum.php?f=55&sid=dfbad1d284fe6cfa1feb73573414b892
Thanks a lot, Coral.
I'll check.
I'll check.
Coral wrote: Thu Nov 11, 2021 4:31 am If you go here and check a sample of the buttons you will surly manage to create your own.
