Hi there,
I am running the latest build (3.0.0.74) on Windows 11.
The program crashes after a few seconds of converting. Is this software still being updated? There hasn't been an update in a long time.
Can anyone help???
Cheers
Crashes on convert?!
Re: Crashes on convert?!
Also tried build 3.0.0.71.
Same thing!
Same thing!
Also, hardware acceleration is not working. It detects my AMD Radeon card, but that is it.
https://imgur.com/a/8onj7PX
Sadly AMD does not support OpenGL.
Other options are CUDA - NVidia and IntelSync -for Intel.
Not much that can be done without NVidia GFX card.
Ok. Fair enough
But what about the app crashing on Windows 11?
And, is it still actively being developed?
Anything crashing on Win11 has to be considered normal problem due new OS.
Whole OS is not stable on all systems yet without any apps installed. Takes time.
All VSO products are under huge upgrade, mostly going to 64bit.
First-in-line is Downloader, other products to follow.
VSO will inform more.
