Input File Location
Foxmaster
Input File Location
Post by Foxmaster »
Is there a way to specify/change where ConvertXtoDVD looks for input files?
Re: Input File Location
Except for the first time default, CXD will always look in the folder you last used as an input source. If that folder doesn't exist, then I think it defaults back to its first time default. Which, again I think, is the Documents folder.
So, to achieve what you want, I think all you can really do is create a folder or choose an existing one and put all files you'd ever want to load in CXD in that folder. And then at some point, open a file from this folder in CXD for input. Then, CXD should remember that folder each time you attempt to open a file again.
That's about the extent of what is possible, I think.
