[Solved] link to versiondownload doesn't work
bertoss
Post by bertoss »
I will download the latest beta version convertxtodvd 7.0.0.73, but the link doesn't work.
Can sombody help me?
At the moment I use convertxtodvd 7.0.0.73, but I want to re-install
Gr. Bert
Anaïs
Re: link to versiondownload doesn't work
Post by Anaïs »
We'll sort this out together!
Please run, fill and send this out:
Anaïs
Anaïs,
VSO Support Team
Hi Bertoss. If you are referring to the window security false positive pop up screen, simply click on box to say ok, and the file downloads fine
bertoss
Post by bertoss »
Hello Anais,
Thank you for your reaction but the link go gave doesn't work.
When I click on the link, nothing happend.
bertoss
Post by bertoss »
That is also the problem when I click on the link to download version 7.0.0.73
Confirming this; clicking on beta download link and nothing happens, right after the link looks odd. Clicking on latest release provides file as supposed.
from main vso page, not forum. all ok but with windows security false positive. Images below are in reverse order.
Click on version history, then it brings up the version you want 70073, click on "keep" to override the windows security false positive
11-06-2022 7-07-39 AM.jpg (21.72 KiB) Viewed 9625 times
bertoss
Post by bertoss »
The link still doesn't work. The link turns blue, but nothing happend when I click the link.
I tried on 2 computers. (have you tried yourself to download version 7.0.0.73?)
I am using vso convertxtodvd for many years and never had this problem.
Is it possible that you give me the working link?
Dr. Bert
bertoss
Post by bertoss »
Problem solved.
I have download the beta version from another site,that I found with google.
Thanks for all your support.
Gr. Bert
Gripweed
Post by Gripweed »
Here's the correct link: https://download.vso-software.fr/archiv ... 0.0.73.exe
All it was was that the listing used "http" rather than "https". Most current browsers refuse to go to websites that don't use SSL encryption.
Link is fixed now!
