[Solved] ConvertXtoDVD 7 not burning
willow11
Post by willow11 »
Lately, when downloading movie files I cannot convert them to DVD, keeps stating "we have a problem here" one or more files were not downloaded, but they do play on my pc, but not VLC. When I open for mp4 or mkv on pc they open and play. But cannot convert.
:std_log='C:\Users\Mike Hagen\AppData\Roaming\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_mainlog.20220623.110129.757.log'
:library=false
:app_name=ConvertXtoDvd.exe
:app_version=7.0.0.73
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
11:02:24.818 Exception File "\\?\C:\Users\Mike Hagen\Downloads\Compressed\Doctor.Strange.in.the.Multiverse.of.Madness.2022.1080p.WEBRip.x264-RARBG_2\Doctor.Strange.in.the.Multiverse.of.Madness.2022.1080p.WEBRip.x264-RARBG\Doctor.Strange.in.the.Multiverse.of.Madness.2022.1080p.WEBRip.x264-RARBG.mp4" ignored. Unrecoverable error '' while reading.
11:02:24.818 Group Ignored file(s)
11:02:24.065 Important Loaded with result [File ]
11:02:23.370 Info Loading: "\\?\C:\Users\Mike Hagen\Downloads\Compressed\Doctor.Strange.in.the.Multiverse.of.Madness.2022.1080p.WEBRip.x264-RARBG_2\Doctor.Strange.in.the.Multiverse.of.Madness.2022.1080p.WEBRip.x264-RARBG\Doctor.Strange.in.the.Multiverse.of.Madness.2022.1080p.WEBRip.x264-RARBG.mp4 - File" 1/1
11:02:23.123 Info Sources filtered, found 1 protocols
11:02:22.539 Info Added protocol \\?\C:\Users\Mike Hagen\Downloads\Compressed\Doctor.Strange.in.the.Multiverse.of.Madness.2022.1080p.WEBRip.x264-RARBG_2\Doctor.Strange.in.the.Multiverse.of.Madness.2022.1080p.WEBRip.x264-RARBG\Doctor.Strange.in.the.Multiverse.of.Madness.2022.1080p.WEBRip.x264-RARBG.mp4, candidate 1/1
11:02:22.252 Info Found 1 candidates
11:02:21.704 Info Filtering sources
11:02:21.704 Group Loading file(s)
11:01:26.642 Info Personnal resources size (C:\Users\Mike Hagen\Documents\ConvertXtoDVD_Resources\): 0MB, 0 file(s)
11:01:26.422 Info Monotonizer size (C:\ProgramData\vso\vsomsl): 0MB, 220 file(s)
11:01:26.191 Info Thumb cache size (C:\ProgramData\VSO\vsothumbs): 1.84GB, 1489 file(s)
11:01:25.799 Info Logs and templates size (C:\ProgramData\VSO\ConvertXtoDVD\7\): 74MB, 664 file(s)
11:01:25.531 Group Folder data
11:01:25.516 Info Menu templates loaded: 20
11:01:24.041 Info License status: active customer license
11:01:24.041 Info License type: commercial (online activated)
11:01:24.040 Info Computer ID: 412180
11:01:24.040 Group License
11:01:19.897 Info Loading templates from: "C:\Users\Mike Hagen\Documents\ConvertXtoDVD_Resources\Templates\"
11:01:19.897 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\7\Templates\"
11:01:19.895 ------------ **************************ConvertXtoDvd.exe:4956 Log session start 2022-06-23 at 11:01:19.242***************************
11:01:19.892 Info 2 writer(s) found.
11:01:19.867 Group Burn engine events
I have used ConvertXtoDVD for years, havenot run into this for this long.
Thanks in advance
willow
Re: ConvertXtoDVD 7 not burning
Source file is bad. Check the file or redownload.
As was said, it's the source file. More than half of the files found online are generally corrupt in some manner. You could try to see if you can fix it with a free piece of software called AVIDeMux. Load the file in that and choose a different Video option other than Copy like say x264. You may want to change the Audio option, too, just to be safe. Then, save that new file. This saving process will probably take some time. Then, see if CXD doesn't choke on the AVIDeMux output.
willow11
Post by willow11 »
Thank guys, I will keep checking the source a lot more in detail. Thanks
