Version 2.0.0.102 Doesn't detect OpenCL anymore
revangel
Post by revangel »
I've tried testing the version 2.0.0.102, but for some reason on my AMD 3400G CPU, it no longer detects the Kronos openCL function (Not available). It detects the integrated graphics "AMD RX 11 graphics" but the Kronos openCL is disabled. I've tried other products which are using the openCL and they all work just fine. So, there must be something wrong with your product. It's probably no longer compatible with the latest drivers from AMD for the 3400G CPU. Can you please try and remedy this.
Thank you!
Re: Version 2.0.0.102 Doesn't detect OpenCL anymore
.102 seems to only have fixed a Memory Leak and creates issues with very large files and high ratio files I guess, 4K etc...
Maybe for now .100 would still do the job for you !
Right now, ConvertXtoVideo is not being worked on...
viewtopic.php?p=108493#p108493
Let VSO work on their conversion engine and let's see when ConvertXVideo get's worked on !
http://download.vso-software.fr/archive ... .0.100.exe
If you need the .100 installer
Katia
Post by Katia »
It is possible if AMD changed their libraries that our software doesn't detect it anymore.
We will check it, thank for letting us know.
VSO Support Team
