problem with convertxtodvd 7
urdo11
Post by urdo11 »
Hello, the converter does not let me finish the process, when it takes approximately 95%, the following message appears "conversion canceled by the user", since I have not canceled anything, the conversion stops automatically, also it does not let me change the destination where the files will be stored, it only lets me save them in the documents folder. I hope you can help me as I pay for this product.
Re: problem with convertxtodvd 7
Post full conversion or error log please.
urdo11
Post by urdo11 »
hello I leave capture of the error, I leave the link below: https://drive.google.com/uc?id=1IGPSy8D ... t=download
That link is not accessible. Set permissions correctly.
eddie11013
Post by eddie11013 »
I once had this issue and it was traced to the subtitle track, upon deletion of the subtitle the issue was resolved. Have a look at my previous post: viewtopic.php?f=56&t=21667&hilit=conver ... y+the+user
Hope this helps
Good luck
As to the OP's second issue, changing the output destination, do you mean if you change the setting in Default Settings --> Global Settings --> General --> Working Folder, your VIDEO_TS is not saved to that folder?
urdo11
Post by urdo11 »
Now you can see the link correctly. I was able to solve the problem, apparently the program had a problem with one of the videos in the project, I have the conversion in two steps activated, the first conversion did not have any problem, but in the second conversion the video presented problems and it did not let me finish the process
