menu music problem
Wolf-man451
menu music problem
Post by Wolf-man451 »
I'm having a problem with my custom music file playing correctly on my main menu. I set it to start the song at a certain point and play for a certain amount of time. It seems that no matter what I do, it stops the song a few seconds in and it goes back to the beginning. I'm not sure what I'm doing wrong. I'm including pictures of how I have it set up, Any help would be great. Thank you.
https://drive.google.com/file/d/1DSadoE ... sp=sharing
https://drive.google.com/file/d/1ys-JdS ... sp=sharing
Katia
Re: menu music problem
Post by Katia »
You set 00m55s as a start point for your audio file. But your menu lasts only 1m16s. So if music starts at 55s, it will play for 21 seconds and stop, and then menu gets back to the start.
You need to set the start of your audio file at the beginning of the menu, or to make your menu last longer if you want.
VSO Support Team
