Version 7 does not properly convert VRO files
The latest gold release of Version 7 does not properly convert VRO files. I used an input for a VRO conversion I made in 2015 with that then current version of CXD. 7.0.0.69 does not properly handle this same input. What happens is at random points, there's a stretch of the proper audio, but the video is a still image from video earlier in the VRO stream.
I tried other VRO inputs, but got other problems. Some VRO's don't fully load into CXD. CXD only loads a portion of the VRO for conversion, cutting off the rest of the video from input.
Thanks!
Katia
Re: Version 7 does not properly convert VRO files
Post by Katia »
Can you send us some of your vro files?
You can use our Filegator to upload the file: https://upload.vso-software.fr/
Username: VSO_users
Password: VSO_users
Please send us a mail once it's over: support@vsosoftware.fr
VSO Support Team
I'd be happy to provide the problematic file, but it's a bit of a problem itself. It's like 3.6 GB. If you have a means for me to upload something that large somewhere, I'd be glad to send it.
I'm attempting to send them to File Gator, but I don't know how that will work. I'll see if it does and e-mail to the supplied address if/when it completes.
Thanks!
File appeared to successfully upload to FileGator. E-mail sent to requested address. Thanks!
