Conversion failed 2
skydropco
Conversion failed 2
Post by skydropco »
Ok, I hadn't used ConvertXtoDVD 7 for a few weeks and I now had some files.
to convert. All went well until it was time to burn some discs, couldn't get out of the starting gate.
Here's the log activy tried burning a few times with the same result here...
16:14:48.227 Error WRITE FAILED: Write aborted by user
16:14:32.760 Info Request to abort ISO creation process initiated...
^^^Repeated 2 Times in 7 second(s) 793 millisecond(s)^^^
16:14:24.741 Info Try #6 - command time 19.986 Sec.
16:14:12.047 Info Request to abort write process initiated...
16:14:04.748 Info Try #5 - command time 20.027 Sec.
16:13:44.715 Info Try #4 - command time 16.576 Sec.
16:13:28.128 Info Try #3 - command time 16.814 Sec.
16:13:11.305 Info Try #2 - command time 17.699 Sec.
16:12:53.602 Info Try #1 - command time 31.303 Sec.
16:12:53.595 Info Sense at LBA 0 (32) - 03 73 03 [MEDIUM ERROR, power calibration fail (CD-burner is dirty)]
16:12:22.132 Info Write started 1083472 sectors to write
16:12:22.129 Info Init DVD-R DAO Success
16:12:17.101 Info Write speed set at x4.0 (5540 kB/s) CAV
16:12:17.071 Info Available write speed: x8.0 (11080 kB/s) CAV *, x4.0 (5540 kB/s) CAV
16:12:17.067 Info Media ID: MCC 03RG20
16:12:16.630 Info Scanned files #9, folder #2 - total size 2217826304 b. (2.07 GB.)
16:12:16.625 Info Inserted media type : dvd-r
16:12:16.424 Info Volume ID: Gordon Lightfoot - The Best Live Clips - 1960s and 1970s
16:12:16.418 Info Folder: C:\Users\Gary Field\Documents\ConvertXtoDVD\Gordon Lightfoot - The Best Live Clips - 1960s and 1970s\
16:12:16.414 Info Write started
16:12:15.219 Info DVD Video burn process started
16:12:00.307 Info Writable disc dvd-r inserted. Ready to write
16:11:58.209 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
16:11:58.209 Info Drive has USB physical interface
16:11:58.208 Info New Drive selected : [D] Dell DVD+/-RW DW316 A1C2 (USB)
15:40:17.902 Warning No writer found. Only ISO image destination is available
15:40:17.893 Group Burn engine events
Re: Conversion failed 2
This is totally different issue.
Check your burner and media.
