Hi everyone,
I have selected in the settings no menu for a single title.
At the end of the disc, however, the menu turns up.
Is there any way to have NO menu at all, either at the start or end?
Cheers
Don't want a menu at all!
Re: Don't want a menu at all!
After uploading a video in ConvertX you have Menu options above the video, if you click on "edit menu" you can chose "no menu" structure and select it. This way you won't have menu at all.
VSO Support Team
