Odd new problem
Kittysafe
Odd new problem
Post by Kittysafe »
I used to be able to title a file, then arrow key down to move to the next one, or hit enter to close off a title, but now no ket presses like this work or do anything within the program... any idea why?
Thanks!
ConvertX is up to date and licensed.
Re: Odd new problem
Are you meaning under Main Titles and the Titleset #1 Titleset#2 etc etc
I can edit the tile set names OK
Kittysafe
Re: Odd new problem
Post by Kittysafe »
Yea this is the first time arrow keys aren't working
Re: Odd new problem
arrow keys work for me ok, not something simple like numlock on?
Kittysafe
Re: Odd new problem
Post by Kittysafe »
I will test that out, thank you.
Kittysafe
Re: Odd new problem
Post by Kittysafe »
Enter key works if the title isn't being edited, but i used to be able to hit enter to finish editing, then hit the arrow key down... the enter key isn't doing anything?
Katia
Re: Odd new problem
Post by Katia »
Hey, if enter key doesn't work - click somewhere outside the edit field, it will enter the new name
VSO Support Team
