The way CXD currently works, it will convert a Blu-Ray source to DVD, but it will only convert the main feature title Any other streams or extras are not available for input. I'm looking for something that will convert all available title sets from a Blu-Ray to DVD. Would VSO's ConvertXToVideo do this? And does ConvertXToVideo create DVD's with menus in the same style as CXD? Or would I have to use ConvertXToVideo to create VIDEO_TS first and then load that VIDEO_TS output into CXD to create CXD style DVD menus?
Thanks!
Converting Blu-Ray to DVD
Re: Converting Blu-Ray to DVD
With Convertxtovideo I could not see a disk copy option, but Blu-Ray converter seems to plus option to copy to DVD (but will need a 3rd party decryptor).
I use dvdfab for this type of conversion
CXD mentions using Blu-Ray Converter for such a task I mentioned, but I did not see such an application offered on VSO's website when I checked.
Here is the link
https://www.vso-software.fr/products/bl ... istory.php
Under products old, last real update was in 2019
Ah! I didn't see the Older Products category.
So, would ConvertXToVideo do a better job of it or Blu-Ray Converter?
Not sure, bd converter is very old
Maybe use rewriteable disk to test it, so nothing lost if fails
Blu-Ray Converter was originally created to extract correctly blu-ray discs, but convertXtoVideo can do the job too.
Both have menu creation for DVD output but not so developed as in ConvertXtoDVD.
You can try trial versions to test both programs.
VSO Support Team
