Burning Video's with .265 Audio
wade7575
Post by wade7575 »
I was wondering is there anything I need to burn video files that have .265 audio sound tracks if so what do I need to use and can you provide a link.
Re: Burning Video's with .265 Audio
wade7575
Post by wade7575 »
I tried clicking on the link in the next post Cougar_II but it said the paid isn't available can you post a working link to the tool.
Katia, can you please provide a valid link to the .h265 converter so the output can be used with ConvertXtoDVD.
You also try AviDemux, never used it yet…
https://www.fosshub.com/Avidemux.html
wade7575
Post by wade7575 »
How do you use the link that you posted Cougar do you just install it then run Convertxtodvd.
You have a private message :)
Run your input files in VSO h265 Converter
I have not used ConvertXtoDVD in ages, so I will not be much more help for now...
Hope you get done what is needed !
Emilieffrde
Post by Emilieffrde »
How do you use the link that you posted, Cougar? Do you just install it and then run Convertxtodvd?
VSO UHD converter has been released.
viewtopic.php?t=22454
I would use this software, convert the file to H264 / AC3 audio using the Most Compatible profile.
Then the output will be compatible to work with ConvertXtoDVD
I regulary convert videos with 265 codec and no issues
I think some H265 are ok, but ConvertXtoVideo may have issues with 4k ratios, Opus audio and VP9 Video (Never tried with ConvertXtoVideo).
Without the logs and source file it's hard to see why certain files may not work and some others yes :D
