Quality
mort2130
Quality
Post by mort2130 »
I have both Convertxtodvd and Convertxtohd. The Convertxtodvd quality I cant get really good quuality to DVD , is there a trick to the settings ?
On Convertxtohd , how do u burn to dvd5 or something that will play on any dvd player ?
Re: Quality
DVD is very restricted format.
Quality on DVD is depending on your source file and conversion settings so conversion log is needed.
To be playable on any DVD player it is better to use ConvertXtoDVD as it takes care of compliance.
Katia
Re: Quality
Post by Katia »
As it was already said, all depends on your source file.
You can make some improvements with conversion settings, in "default settings" - "output" - "encoding" check "two pass encoding" and "use best video quality". Note, it will increase conversion time.
In "video processing" you can try to use "Lanczos " or "Cubic" as upscaling and downscaling filters.
VSO Support Team
