ConvertXToDVD 7 audio has "clicking"
A few years ago ConvertXToDVD 7 had an issue with the audio on the DVD having clicking sounds throughout the DVD. This was resolved but now is back again. Any thoughts on why?
Re: ConvertXToDVD 7 audio has "clicking"
You need to check your source audio, its format/codecs.
Sometimes audio file is separated in several streams, in this case you need to select all streams for conversion, not just the first one.
Also, in audio tab below the preview window you can check the output format of your audio and change it. By default it is set on "automatic".
VSO Support Team
Seems to be the DVD player on my computer. Thanks for the advice!
