New user of ConvertXtoHD 3
Hello everyone,
I'm been using VSO Software since 2008 or less :)
But I have never used ConvertXtoHD 3 as I never needed it.
I have started to use it to help VSO find bugs and see what it's all about :) :) :)
I have tried both AVCHD and BluRay outputs.
Here's is my question: On my project I have menus.
But when played with VSO Media Player or VLC, they main "Videos" seems to play one by one, but there is NO MENU at 1st but on the end, some menu comes up, but clicking on the buttons, nothing happens.
So to see those menu working as expected, they *MUST* be played on a true BluRay Player ?
Thank you everyone...
Katia
Re: New user of ConvertXtoHD 3
Post by Katia »
VSO Media Player doesn't show menus, it's normal.
In VLC normally it works. It can bug, but you should see at least something in the beginning.
Have you checked if "auto-start playback" option for menu isn't selected?
VSO Support Team
I will check, and try again for fun ;)
