Project files don't work after update
blackhawk
Post by blackhawk »
I just updated to the latest version, 3.0.0.75. Now project files I saved with earlier versions no longer work. They load and start to process, but fail before completion.
Re: Project files don't work after update
Also cannot rename tileset with this version. Reinstalled previous version and this fixed bug.
Blackhawk:I opened a bug report for you.
https://bugs.vso-software.fr/view.php?id=14226
yoyo57, added your comment to bug:
https://bugs.vso-software.fr/view.php?id=14223
Nemesh
Post by Nemesh »
Hello Blackwawk,
Jaques (VSO Developer) has clearly stated that there will be NO MORE updates/bug-fix versions of the current version of ConvertXtoHD3.
All the issus will be adressed in the upcoming new Video Converter (works underway).
Probaly the first Alpha release will be around 2025 (according to Jaques).
With regards,
Nemesh
Katia
Post by Katia »
Hello everyone,
Jacques fixes small bugs, even if he said he wasn't going to do it :D He won't just work on big projects like h265 in ConvertX.
The bug with renaming files and projects was fixed today.
But we can't reproduce the bug with opening old projects, it works here. Does anyone have the same problem with old project files?
VSO Support Team
Nemesh
Post by Nemesh »
Hallo Katia,
Well, that's a suprise.
Maybe you can ask Jaques to fix the bug I reported some years ago.
They are still all here.
For example this bug in version 3.0.0.74 I reported in 2020: viewtopic.php?f=53&t=21765&p=107019#p107019
I know het can't fix the subtitle problem.
He has explained that to me because the subtitle engine needs to be rewritten.
Or the bug I reported that when you have a multipage menu en ticked Skip Into And Outro it doesn't work.
Happens on the menu from The Big Bang Theory I created and and I send Jaques the project files.
But I guess he was to busy with the downloader he forgot all about that.
With Regards,
Nemesh
