problems abound
judgeraye
problems abound
Post by judgeraye »
got a newish DVD burner a couple of months ago all of a sudden im getting No joy
:std_log='C:\Users\judge\AppData\Roaming\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_mainlog.20230808.101350.838.log'
:library=false
:app_name=ConvertXtoDvd.exe
:app_version=7.0.0.83
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
10:58:07.148 Info Total size 240 Mb., Target size DVD5 4300 Mb., Occupation 5.60%
10:59:11.128 Error WRITE FAILED: near beginning at sector 768
10:59:09.745 Info Disc name: "1110x832 - On"
10:58:07.460 Info Burned folder: "C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On", Min. media size 241 Mb.
10:58:07.144 Info Conversion completed in 00:01:29
10:56:37.543 Info [ ] Loop playback
10:56:37.541 Info [x] Play titles one after the other
10:56:37.539 Info [x] Don't create title menu for single video
10:56:37.537 Info [ ] Return to title menu after titleset playback
10:56:37.535 Info [ ] Skip root menu initially
10:56:37.533 Info [x] Auto-start playback
10:56:37.531 Info Template: My Purple plasma (open style), contains 4 page(s)
10:56:37.531 Group Video DVD menu options
10:56:37.529 Info Video DVD format: NTSC (30 Fps)
10:56:37.527 Info Output target size : DVD-5 (4300 MB)
10:56:37.525 Info Number of core(s) used for encoding : 8
10:56:37.523 Info Number of core(s) used for decoding : 8
10:56:37.521 Info [ ] Use 2 pass encoding
10:56:37.519 Info [x] Use best video quality settings
10:56:37.517 Info [ ] Use hardware decoding (if possible)
10:56:37.515 Info Max simultaneous conversions: 8
10:56:37.515 Group Advanced encoding options
10:58:06.546 ------------ ****************************************File encoded successfully: VTS_01_1.VOB*****************************************
10:58:06.543 Info "ROOT 1/1 (Global 1/1)" menu built successfully
10:58:00.145 Important Starting BD root menu encoding: [Memory load 48%] [Available virtual memory 3457 Mb.]
10:58:00.143 Info Building ROOT menus using template: My Purple plasma (open style)
10:58:00.137 Info DVD sectors written - video: 113668, audio: 4713, subtitle: 0
10:58:00.134 Info video #1 - Processed video frames: 11875 (11865 frames encoded, 10 frames dropped, 0 frames duplicated)
10:56:37.585 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[audio aac main audio 2 Ch. 44100Hz , 96 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 4x3, 29.97Fps, 9200Kbps]
+-[video h264 1110x832 4:3 yuv420p, 30.00Fps, 1199Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_01_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\1110x832 - On.mp4
Video filters used:
- DeInterlace filter: VSO
10:56:37.582 Important Starting video encoding: [Memory load 47%] [Available virtual memory 3443 Mb.]
10:56:37.554 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1110x832 - On.mp4
10:56:37.377 Info Menu fit: Text size reduced from 39.00 to 39.00 in style "Settings menu section title"
10:56:37.372 Info Menu fit: Text size reduced from 41.00 to 39.00 in style "Settings menu section title"
10:56:37.353 Info Menu fit: Text size reduced from 32.00 to 32.00 in style "Captions in navigation buttons for all the project"
^^^Repeated 3 Times in 10 millisecond(s)^^^
10:56:37.348 Info Menu fit: Text size reduced from 34.00 to 32.00 in style "Captions in navigation buttons for all the project"
10:56:37.267 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1110x832 - On.mp4
10:56:37.252 Group ******************** Titleset #1 - ~6 min. File: "1110x832 - On" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:56:37.250 Info Encoding options: Very short Project (Automatic)
10:56:37.248 Info Target size: 4300 Mb.
10:56:37.246 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
10:56:37.244 Important 8 simultaneous conversions allowed
10:56:37.242 Info Don't log FFMpeg log events
10:56:37.240 ------------ ***************************************************Burn settings end****************************************************
10:56:37.238 Info Default speed selected: 4x
10:56:37.236 Info [ ] Delete vsomsl files after burn complete
10:56:37.234 Info [x] Delete output folder after burn complete
10:56:37.232 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
10:56:37.230 Info SAO setting: Automatic
10:56:37.229 Info [x] Burn result to disk / as ISO file in working folder
10:56:37.226 ------------ **************************************************Burn settings begin***************************************************
10:56:37.226 Group Encoding session started at 10:56:37 AM: 1 titleset(s) to encode -> Completed in 00:01:29|GK_CONVERT_SESSION|
10:56:30.998 Important Loaded with result [File ]
10:56:30.991 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\1110x832 - On.mp4 - File" 1/1
10:56:30.989 Info Sources filtered, found 1 protocols
10:56:30.986 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\1110x832 - On.mp4, candidate 1/1
10:56:30.984 Info Found 1 candidates
10:56:30.971 Info Filtering sources
10:56:30.971 Group Loading file(s)
10:53:47.330 Info Total size 3787 Mb., Target size DVD5 4300 Mb., Occupation 88.08%
10:55:11.170 Info Disc name: "1110x832 - On"
10:53:47.581 Info Burned folder: "C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On", Min. media size 3.7 GB.
10:53:47.327 Info Conversion completed in 00:36:41
10:53:46.412 Info "TITLE 3/3 (Global 3/3)" menu built successfully
10:53:20.018 Info "TITLE 2/3 (Global 2/3)" menu built successfully
10:52:47.634 Info "TITLE 1/3 (Global 1/3)" menu built successfully
10:52:22.452 Important Starting BD title menus encoding: [Memory load 47%] [Available virtual memory 3356 Mb.]
10:52:22.449 Info Building TITLE menu
10:17:05.273 Info [ ] Loop playback
10:17:05.272 Info [x] Play titles one after the other
10:17:05.271 Info [ ] Don't create title menu for single video
10:17:05.270 Info [x] Return to title menu after titleset playback
10:17:05.270 Info [ ] Skip root menu initially
10:17:05.269 Info [x] Auto-start playback
10:17:05.268 Info Template: My Purple plasma (open style), contains 4 page(s)
10:17:05.268 Group Video DVD menu options
10:17:05.267 Info Video DVD format: NTSC (30 Fps)
10:17:05.266 Info Output target size : DVD-5 (4300 MB)
10:17:05.265 Info Number of core(s) used for encoding : 8
10:17:05.264 Info Number of core(s) used for decoding : 8
10:17:05.263 Info [ ] Use 2 pass encoding
10:17:05.263 Info [x] Use best video quality settings
10:17:05.262 Info [ ] Use hardware decoding (if possible)
10:17:05.261 Info Max simultaneous conversions: 8
10:17:05.261 Group Advanced encoding options
10:31:51.513 ------------ ****************************************File encoded successfully: VTS_15_1.VOB*****************************************
10:31:51.509 Info "ROOT 1/1 (Global 1/1)" menu built successfully
10:30:58.457 Important Starting BD root menu encoding: [Memory load 52%] [Available virtual memory 2847 Mb.]
10:30:58.454 Info Building ROOT menus using template: My Purple plasma (open style)
10:30:58.445 Info DVD sectors written - video: 4091, audio: 360, subtitle: 0
10:30:58.443 Info video #1 - Processed video frames: 901 (902 frames encoded, 0 frames dropped, 1 frames duplicated)
10:30:25.779 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[audio [eng] aac main audio 2 Ch. 48000Hz , 128 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, 29.97Fps, 2060Kbps]
+-[video h264 852x480 16:9 yuv420p, 29.97Fps, 1118Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_15_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\33555hf.mp4
Video filters used:
10:30:25.774 Important Starting video encoding: [Memory load 52%] [Available virtual memory 2843 Mb.]
10:30:25.735 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\33555hf.mp4
10:17:04.098 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\33555hf.mp4
10:17:04.097 Group ******************** Titleset #15 - ~1 min. File: "33555hf" -> VTS_15_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:45:12.089 ------------ ****************************************File encoded successfully: VTS_14_1.VOB*****************************************
10:45:12.086 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
10:44:52.482 Info "ROOT 1/1 (Global 1/2)" menu built successfully
10:44:26.147 Important Starting BD root menu encoding: [Memory load 52%] [Available virtual memory 2938 Mb.]
10:44:26.145 Info Building ROOT & CHAPTERS, menus using template: My Purple plasma (open style)
10:44:26.117 Info DVD sectors written - video: 179443, audio: 16838, subtitle: 0
10:44:26.115 Info video #1 - Processed video frames: 42384 (42384 frames encoded, 0 frames dropped, 0 frames duplicated)
10:30:14.858 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 640x360 16:9 yuv420p, 29.97Fps, 650Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_14_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\ersera.mp4
Video filters used:
10:30:14.847 Info Chapters to generate: 5 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, )
10:30:14.845 Important Starting video encoding: [Memory load 53%] [Available virtual memory 2823 Mb.]
10:30:14.791 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\ersera.mp4
10:17:03.989 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\ersera.mp4
10:17:03.988 Group ******************** Titleset #14 - ~23 min. File: "ersera" -> VTS_14_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:52:22.309 ------------ ****************************************File encoded successfully: VTS_13_1.VOB*****************************************
10:52:22.306 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
10:50:42.158 Info "ROOT 1/1 (Global 1/2)" menu built successfully
10:50:13.783 Important Starting BD root menu encoding: [Memory load 47%] [Available virtual memory 3356 Mb.]
10:50:13.782 Info Building ROOT & CHAPTERS, menus using template: My Purple plasma (open style)
10:50:13.760 Info DVD sectors written - video: 173083, audio: 16082, subtitle: 0
10:50:13.758 Info video #1 - Processed video frames: 40093 (40480 frames encoded, 0 frames dropped, 387 frames duplicated)
10:29:29.404 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[audio aac main audio 2 Ch. 24000Hz , 192 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 29.97Fps -> 29.97Fps, 2060Kbps]
+-[video h264 3840x2160 16:9 yuv420p, 29.68Fps, 10758Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_13_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\3840x2160.mp4
Video filters used:
10:29:29.401 Info Chapters to generate: 5 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, )
10:29:29.398 Important Starting video encoding: [Memory load 51%] [Available virtual memory 2936 Mb.]
10:29:28.679 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\3840x2160.mp4
10:17:03.837 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\3840x2160.mp4
10:17:03.836 Group ******************** Titleset #13 - ~22 min. File: "3840x2160" -> VTS_13_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:44:56.440 ------------ ****************************************File encoded successfully: VTS_12_1.VOB*****************************************
10:44:56.437 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
10:44:13.219 Info "ROOT 1/1 (Global 1/2)" menu built successfully
10:43:39.220 Important Starting BD root menu encoding: [Memory load 53%] [Available virtual memory 2892 Mb.]
10:43:39.217 Info Building ROOT & CHAPTERS, menus using template: My Purple plasma (open style)
10:43:39.183 Info DVD sectors written - video: 179849, audio: 16676, subtitle: 0
10:43:39.180 Info video #1 - Processed video frames: 41968 (41976 frames encoded, 0 frames dropped, 8 frames duplicated)
10:26:37.953 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1920x1080 16:9 yuv420p, 29.96Fps, 2602Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_12_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (4).mp4
Video filters used:
10:26:37.951 Info Chapters to generate: 5 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, )
10:26:37.949 Important Starting video encoding: [Memory load 50%] [Available virtual memory 3040 Mb.]
10:26:37.748 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (4).mp4
10:17:03.706 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (4).mp4
10:17:03.704 Group ******************** Titleset #12 - ~23 min. File: "1920x1080 - (4)" -> VTS_12_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:30:24.987 ------------ ****************************************File encoded successfully: VTS_11_1.VOB*****************************************
10:30:24.985 Info "ROOT 1/1 (Global 1/1)" menu built successfully
10:29:28.969 Important Starting BD root menu encoding: [Memory load 51%] [Available virtual memory 2956 Mb.]
10:29:28.960 Info Building ROOT menus using template: My Purple plasma (open style)
10:29:28.939 Info DVD sectors written - video: 52701, audio: 5386, subtitle: 0
10:29:28.915 Info video #1 - Processed video frames: 13572 (13561 frames encoded, 11 frames dropped, 0 frames duplicated)
10:23:44.395 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1920x1080 16:9 yuv420p, 29.99Fps, 2605Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_11_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 (2).mp4
Video filters used:
10:23:44.393 Important Starting video encoding: [Memory load 50%] [Available virtual memory 3048 Mb.]
10:23:44.176 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 (2).mp4
10:17:03.592 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 (2).mp4
10:17:03.591 Group ******************** Titleset #11 - ~7 min. File: "1920x1080 (2)" -> VTS_11_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:29:28.396 ------------ ****************************************File encoded successfully: VTS_10_1.VOB*****************************************
10:29:28.381 Info "ROOT 1/1 (Global 1/1)" menu built successfully
10:28:37.558 Important Starting BD root menu encoding: [Memory load 49%] [Available virtual memory 3079 Mb.]
10:28:37.556 Info Building ROOT menus using template: My Purple plasma (open style)
10:28:37.547 Info DVD sectors written - video: 53060, audio: 6091, subtitle: 0
10:28:37.545 Info video #1 - Processed video frames: 15347 (15335 frames encoded, 12 frames dropped, 0 frames duplicated)
10:22:19.493 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1920x1080 16:9 yuv420p, 29.99Fps, 2598Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_10_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (3).mp4
Video filters used:
10:22:19.491 Important Starting video encoding: [Memory load 49%] [Available virtual memory 3057 Mb.]
10:22:19.264 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (3).mp4
10:17:03.492 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (3).mp4
10:17:03.490 Group ******************** Titleset #10 - ~8 min. File: "1920x1080 - (3)" -> VTS_10_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:30:14.602 ------------ ****************************************File encoded successfully: VTS_09_1.VOB*****************************************
10:30:14.599 Info "ROOT 1/1 (Global 1/1)" menu built successfully
10:29:21.507 Important Starting BD root menu encoding: [Memory load 49%] [Available virtual memory 3075 Mb.]
10:29:21.505 Info Building ROOT menus using template: My Purple plasma (open style)
10:29:21.497 Info DVD sectors written - video: 71572, audio: 6733, subtitle: 0
10:29:21.495 Info video #1 - Processed video frames: 16966 (16952 frames encoded, 14 frames dropped, 0 frames duplicated)
10:21:42.991 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1920x1080 16:9 yuv420p, 30.00Fps, 2605Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_09_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - P.mp4
Video filters used:
10:21:42.989 Important Starting video encoding: [Memory load 51%] [Available virtual memory 3084 Mb.]
10:21:42.869 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - P.mp4
10:17:03.395 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - P.mp4
10:17:03.394 Group ******************** Titleset #9 - ~9 min. File: "1920x1080 - P" -> VTS_09_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:26:36.764 ------------ ****************************************File encoded successfully: VTS_08_1.VOB*****************************************
10:26:36.761 Info "ROOT 1/1 (Global 1/1)" menu built successfully
10:25:43.761 Important Starting BD root menu encoding: [Memory load 49%] [Available virtual memory 3070 Mb.]
10:25:43.760 Info Building ROOT menus using template: My Purple plasma (open style)
10:25:43.753 Info DVD sectors written - video: 81062, audio: 7529, subtitle: 0
10:25:43.751 Info video #1 - Processed video frames: 15808 (15809 frames encoded, 0 frames dropped, 1 frames duplicated)
10:17:39.215 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 25.00Fps -> 29.97Fps, 2060Kbps]
+-[video h264 1920x1080 16:9 yuv420p, 25.00Fps, 2600Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_08_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (2).mp4
Video filters used:
10:17:39.212 Important Starting video encoding: [Memory load 52%] [Available virtual memory 3118 Mb.]
10:17:39.107 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (2).mp4
10:17:03.297 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (2).mp4
10:17:03.295 Group ******************** Titleset #8 - ~10 min. File: "1920x1080 - (2)" -> VTS_08_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:44:05.694 ------------ ****************************************File encoded successfully: VTS_07_1.VOB*****************************************
10:44:05.691 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
10:43:03.242 Info "ROOT 1/1 (Global 1/2)" menu built successfully
10:42:31.247 Important Starting BD root menu encoding: [Memory load 51%] [Available virtual memory 2989 Mb.]
10:42:31.245 Info Building ROOT & CHAPTERS, menus using template: My Purple plasma (open style)
10:42:31.217 Info DVD sectors written - video: 220862, audio: 20492, subtitle: 0
10:42:31.215 Info video #1 - Processed video frames: 51554 (51583 frames encoded, 0 frames dropped, 29 frames duplicated)
10:17:34.480 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1920x1080 16:9 yuv420p, 29.95Fps, 2596Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_07_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 -.mp4
Video filters used:
10:17:34.477 Info Chapters to generate: 6 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, )
10:17:34.476 Important Starting video encoding: [Memory load 51%] [Available virtual memory 3202 Mb.]
10:17:34.271 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 -.mp4
10:17:03.162 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 -.mp4
10:17:03.161 Group ******************** Titleset #7 - ~28 min. File: "1920x1080 -" -> VTS_07_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:23:43.814 ------------ ****************************************File encoded successfully: VTS_06_1.VOB*****************************************
10:23:43.812 Info "ROOT 1/1 (Global 1/1)" menu built successfully
10:22:53.722 Important Starting BD root menu encoding: [Memory load 49%] [Available virtual memory 3076 Mb.]
10:22:53.721 Info Building ROOT menus using template: My Purple plasma (open style)
10:22:53.713 Info DVD sectors written - video: 62173, audio: 5835, subtitle: 0
10:22:53.712 Info video #1 - Processed video frames: 12252 (12253 frames encoded, 0 frames dropped, 1 frames duplicated)
10:17:29.548 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1920x1080 16:9 yuv420p, 25.00Fps, 2606Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_06_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - D.mp4
Video filters used:
10:17:29.547 Important Starting video encoding: [Memory load 50%] [Available virtual memory 3295 Mb.]
10:17:29.414 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - D.mp4
10:17:03.064 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - D.mp4
10:17:03.062 Group ******************** Titleset #6 - ~8 min. File: "1920x1080 - D" -> VTS_06_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:38:59.340 ------------ ****************************************File encoded successfully: VTS_05_1.VOB*****************************************
10:38:59.336 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
10:37:55.293 Info "ROOT 1/1 (Global 1/2)" menu built successfully
10:37:17.161 Important Starting BD root menu encoding: [Memory load 52%] [Available virtual memory 2952 Mb.]
10:37:17.160 Info Building ROOT & CHAPTERS, menus using template: My Purple plasma (open style)
10:37:17.126 Info DVD sectors written - video: 166133, audio: 15429, subtitle: 0
10:37:17.125 Info video #1 - Processed video frames: 38829 (38838 frames encoded, 0 frames dropped, 9 frames duplicated)
10:17:24.701 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1920x1080 16:9 yuv420p, 29.96Fps, 2596Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_05_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - B.mp4
Video filters used:
10:17:24.700 Info Chapters to generate: 5 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, )
10:17:24.698 Important Starting video encoding: [Memory load 49%] [Available virtual memory 3375 Mb.]
10:17:24.593 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - B.mp4
10:17:02.932 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - B.mp4
10:17:02.930 Group ******************** Titleset #5 - ~21 min. File: "1920x1080 - B" -> VTS_05_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:37:14.104 ------------ ****************************************File encoded successfully: VTS_04_1.VOB*****************************************
10:37:14.091 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
10:36:02.123 Info "ROOT 1/1 (Global 1/2)" menu built successfully
10:35:14.990 Important Starting BD root menu encoding: [Memory load 53%] [Available virtual memory 2843 Mb.]
10:35:14.988 Info Building ROOT & CHAPTERS, menus using template: My Purple plasma (open style)
10:35:14.934 Info DVD sectors written - video: 157866, audio: 14628, subtitle: 0
10:35:14.932 Info video #1 - Processed video frames: 36814 (36821 frames encoded, 0 frames dropped, 7 frames duplicated)
10:17:19.848 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1920x1080 16:9 yuv420p, 29.96Fps, 2593Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_04_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080.mp4
Video filters used:
10:17:19.847 Info Chapters to generate: 5 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, )
10:17:19.846 Important Starting video encoding: [Memory load 48%] [Available virtual memory 3463 Mb.]
10:17:19.765 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080.mp4
10:17:02.802 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080.mp4
10:17:02.801 Group ******************** Titleset #4 - ~20 min. File: "1920x1080" -> VTS_04_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:35:47.071 ------------ ****************************************File encoded successfully: VTS_03_1.VOB*****************************************
10:35:47.068 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
10:34:58.171 Info "ROOT 1/1 (Global 1/2)" menu built successfully
10:34:11.835 Important Starting BD root menu encoding: [Memory load 52%] [Available virtual memory 2869 Mb.]
10:34:11.833 Info Building ROOT & CHAPTERS, menus using template: My Purple plasma (open style)
10:34:11.792 Info DVD sectors written - video: 144973, audio: 13511, subtitle: 0
10:34:11.790 Info video #1 - Processed video frames: 34039 (34009 frames encoded, 30 frames dropped, 0 frames duplicated)
10:17:14.979 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1280x720 16:9 yuv420p, 30.00Fps, 1197Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_03_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\1280x720 (2).mp4
Video filters used:
10:17:14.977 Info Chapters to generate: 4 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, )
10:17:14.976 Important Starting video encoding: [Memory load 47%] [Available virtual memory 3547 Mb.]
10:17:14.940 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1280x720 (2).mp4
10:17:02.698 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1280x720 (2).mp4
10:17:02.697 Group ******************** Titleset #3 - ~18 min. File: "1280x720 (2)" -> VTS_03_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:21:42.295 ------------ ****************************************File encoded successfully: VTS_02_1.VOB*****************************************
10:21:42.293 Info "ROOT 1/1 (Global 1/1)" menu built successfully
10:20:57.835 Important Starting BD root menu encoding: [Memory load 51%] [Available virtual memory 3122 Mb.]
10:20:57.833 Info Building ROOT menus using template: My Purple plasma (open style)
10:20:57.824 Info DVD sectors written - video: 39177, audio: 3620, subtitle: 0
10:20:57.823 Info video #1 - Processed video frames: 9120 (9113 frames encoded, 7 frames dropped, 0 frames duplicated)
10:17:10.157 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1280x720 16:9 yuv420p, 29.99Fps, 1206Kbps ]
Output file: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\VIDEO_TS\VTS_02_1.VOB (DVD NTSC)
Input file: C:\Users\judge\OneDrive\Desktop\Documents\E Books\1280x720.mp4
Video filters used:
10:17:10.156 Important Starting video encoding: [Memory load 47%] [Available virtual memory 3599 Mb.]
10:17:10.126 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1280x720.mp4
10:17:02.605 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1280x720.mp4
10:17:02.604 Group ******************** Titleset #2 - ~5 min. File: "1280x720" -> VTS_02_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:22:18.133 ------------ ****************************************File encoded successfully: VTS_01_1.VOB*****************************************
10:22:18.131 Info "ROOT 1/1 (Global 1/1)" menu built successfully
10:21:27.945 Important Starting BD root menu encoding: [Memory load 51%] [Available virtual memory 3113 Mb.]
10:21:27.943 Info Building ROOT menus using template: My Purple plasma (open style)
10:21:27.936 Info DVD sectors written - video: 50864, audio: 4713, subtitle: 0
10:21:27.934 Info video #1 - Processed video frames: 11875 (11865 frames encoded, 10 frames dropped, 0 frames duplicated)
10:17:05.317 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 4x3, 29.97Fps, 2060Kbps]
Video filters used:
10:17:05.315 Important Starting video encoding: [Memory load 46%] [Available virtual memory 3656 Mb.]
10:17:05.288 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1110x832 - On.mp4
10:17:02.586 Info Menu fit: Text size reduced from 39.00 to 39.00 in style "Settings menu section title"
10:17:02.582 Info Menu fit: Text size reduced from 41.00 to 39.00 in style "Settings menu section title"
10:17:02.567 Info Menu fit: Text size reduced from 32.00 to 32.00 in style "Captions in navigation buttons for all the project"
^^^Repeated 3 Times in 7 millisecond(s)^^^
10:17:02.563 Info Menu fit: Text size reduced from 34.00 to 32.00 in style "Captions in navigation buttons for all the project"
10:17:02.482 Verbose FFmpeg Opening file C:\Users\judge\OneDrive\Desktop\Documents\E Books\1110x832 - On.mp4
10:17:02.473 Group ******************** Titleset #1 - ~6 min. File: "1110x832 - On" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
10:17:02.465 Info Encoding options: Long Project (Automatic)
10:17:02.464 Info Target size: 4300 Mb.
10:17:02.461 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
10:17:02.460 Important 8 simultaneous conversions allowed
10:17:02.457 Info Don't log FFMpeg log events
10:17:02.456 ------------ ***************************************************Burn settings end****************************************************
10:17:02.456 Info Default speed selected: 4x
10:17:02.455 Info [ ] Delete vsomsl files after burn complete
10:17:02.454 Info [x] Delete output folder after burn complete
10:17:02.454 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
10:17:02.453 Info SAO setting: Automatic
10:17:02.452 Info [x] Burn result to disk / as ISO file in working folder
10:17:02.451 ------------ **************************************************Burn settings begin***************************************************
10:17:02.451 Group Encoding session started at 10:17:02 AM: 15 titleset(s) to encode -> Completed in 00:36:41|GK_CONVERT_SESSION|
10:16:55.617 Important Loaded with result [File ]
10:16:55.611 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\33555hf.mp4 - File" 15/15
10:16:55.611 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\ersera.mp4 - File" 14/15
10:16:55.610 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\3840x2160.mp4 - File" 13/15
10:16:55.609 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (4).mp4 - File" 12/15
10:16:55.608 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 (2).mp4 - File" 11/15
10:16:55.607 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (3).mp4 - File" 10/15
10:16:55.606 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - P.mp4 - File" 9/15
10:16:55.605 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (2).mp4 - File" 8/15
10:16:55.604 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 -.mp4 - File" 7/15
10:16:55.603 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - D.mp4 - File" 6/15
10:16:55.602 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - B.mp4 - File" 5/15
10:16:55.601 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080.mp4 - File" 4/15
10:16:55.601 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\1280x720 (2).mp4 - File" 3/15
10:16:55.600 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\1280x720.mp4 - File" 2/15
10:16:55.599 Info Loading: "C:\Users\judge\OneDrive\Desktop\Documents\E Books\1110x832 - On.mp4 - File" 1/15
10:16:55.598 Info Sources filtered, found 15 protocols
10:16:55.597 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\33555hf.mp4, candidate 15/15
10:16:55.596 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\ersera.mp4, candidate 14/15
10:16:55.585 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\3840x2160.mp4, candidate 13/15
10:16:55.584 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (4).mp4, candidate 12/15
10:16:55.582 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 (2).mp4, candidate 11/15
10:16:55.581 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (3).mp4, candidate 10/15
10:16:55.580 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - P.mp4, candidate 9/15
10:16:55.579 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - (2).mp4, candidate 8/15
10:16:55.578 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 -.mp4, candidate 7/15
10:16:55.577 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - D.mp4, candidate 6/15
10:16:55.576 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080 - B.mp4, candidate 5/15
10:16:55.575 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\1920x1080.mp4, candidate 4/15
10:16:55.574 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\1280x720 (2).mp4, candidate 3/15
10:16:55.573 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\1280x720.mp4, candidate 2/15
10:16:55.572 Info Added protocol C:\Users\judge\OneDrive\Desktop\Documents\E Books\1110x832 - On.mp4, candidate 1/15
10:16:55.571 Info Found 15 candidates
10:16:55.563 Info Filtering sources
10:16:55.563 Group Loading file(s)
10:13:44.692 Info Disc name: "1920x1080 - Part 2 my uncle Mauricio makes me totally his - XVIDEOS.COM"
10:12:28.877 Info Burned folder: "C:\Users\judge\Documents\ConvertXToDVD\1920x1080 - Part 2 my uncle Mauricio makes me totally his - XVIDEOS.COM", Min. media size 3.71 GB.
10:11:56.358 Info Disc name: "1920x1080 - Part 2 my uncle Mauricio makes me totally his - XVIDEOS.COM"
10:09:38.961 Info Burned folder: "C:\Users\judge\Documents\ConvertXToDVD\1920x1080 - Part 2 my uncle Mauricio makes me totally his - XVIDEOS.COM", Min. media size 3.71 GB.
10:08:43.065 Info Personnal resources size (C:\Users\judge\Documents\ConvertXtoDVD_Resources\): 0MB, 2 file(s)
10:08:42.859 Info Monotonizer size (C:\ProgramData\vso\vsomsl): 0MB, 34 file(s)
10:08:42.657 Info Thumb cache size (C:\ProgramData\VSO\vsothumbs): 197MB, 203 file(s)
10:08:42.439 Info Logs and templates size (C:\ProgramData\VSO\ConvertXtoDVD\7\): 74MB, 663 file(s)
10:08:42.220 Group Folder data
10:08:41.836 Info License status: active customer license
10:08:41.836 Info License type: commercial (online activated)
10:08:41.836 Info Computer ID: 5196693
10:08:41.836 Group License
10:08:41.788 Info Menu templates loaded: 20
10:08:39.657 Info Loading templates from: "C:\Users\judge\Documents\ConvertXtoDVD_Resources\Templates\"
10:08:39.657 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\7\Templates\"
10:08:39.656 ------------ **************************ConvertXtoDvd.exe:3176 Log session start 2023-08-08 at 10:08:39.186***************************
10:59:07.119 Error An error occured in burning process. Drive status code: 22.
10:59:06.404 Error Gave up writing after 21 attempt. Last error: 03 73 03 [MEDIUM ERROR, power calibration fail (CD-burner is dirty)]
10:59:06.397 Info
10:54:47.006 Info Sense at LBA 768 (32) - 03 73 03 [MEDIUM ERROR, power calibration fail (CD-burner is dirty)]
10:54:46.991 Info Try #1 - command time 40.909 Sec.
10:54:46.982 Info Sense at LBA 768 (32) - 03 11 00 [MEDIUM ERROR, read error, unrecovered read error] at LBA 0
10:54:05.873 Info Write started 1939760 sectors to write
10:54:05.863 Info Init DVD+R: Success
10:54:05.856 Warning Laser Power Calibration Failed: 00 00 00 [READY]
10:54:05.844 Info Write speed set at x2.4 (3324 kB/s)
10:54:05.828 Info Available write speed: x2.4 (3324 kB/s) *
10:54:05.821 Info Media ID: RITEK-F16-01
10:54:05.770 Info Scanned files #63, folder #2 - total size 3971395584 b. (3.7 GB.)
10:54:05.763 Info Inserted media type : dvd+r
10:54:05.750 Info Volume ID: 1110x832 - On
10:54:05.739 Info Folder: C:\Users\judge\Documents\ConvertXtoDVD\1110x832 - On\
10:54:05.732 Info Write started
10:54:04.613 Info DVD Video burn process started
10:53:49.612 Info Writable disc dvd+r inserted. Ready to write
10:13:33.918 Error WRITE FAILED: near beginning at sector 768
10:13:29.969 Error An error occured in burning process. Drive status code: 22.
10:13:29.254 Error Gave up writing after 21 attempt. Last error: 03 73 03 [MEDIUM ERROR, power calibration fail (CD-burner is dirty)]
10:13:29.240 Info
10:13:28.910 Info Sense at LBA 768 (32) - 03 73 03 [MEDIUM ERROR, power calibration fail (CD-burner is dirty)] at LBA 0
10:12:53.130 Info Write started 1946064 sectors to write
10:12:53.119 Info Init DVD+R: Success
10:12:53.111 Warning Laser Power Calibration Failed: 00 00 00 [READY]
10:12:53.099 Info Write speed set at x2.4 (3324 kB/s)
10:12:53.083 Info Available write speed: x2.4 (3324 kB/s) *
10:12:53.075 Info Media ID: RITEK-F16-01
10:12:53.025 Info Scanned files #63, folder #2 - total size 3984326656 b. (3.71 GB.)
10:12:53.018 Info Inserted media type : dvd+r
10:12:53.004 Info Volume ID: 1920x1080 - Part 2 my uncle Mauricio makes me totally his - XVIDEOS.COM
10:12:52.993 Info Folder: C:\Users\judge\Documents\ConvertXToDVD\1920x1080 - Part 2 my uncle Mauricio makes me totally his - XVIDEOS.COM\
10:12:52.986 Info Write started
10:12:51.890 Info DVD Video burn process started
10:12:36.944 Info Writable disc dvd+r inserted. Ready to write
10:12:30.911 Info Parsing disc ...
10:10:43.097 Error WRITE FAILED: near beginning at sector 768
10:10:39.094 Error An error occured in burning process. Drive status code: 22.
10:10:38.368 Error Gave up writing after 21 attempt. Last error: 03 73 03 [MEDIUM ERROR, power calibration fail (CD-burner is dirty)]
10:10:38.352 Info .
10:10:38.021 Info Sense at LBA 768 (32) - 03 73 03 [MEDIUM ERROR, power calibration fail (CD-burner is dirty)] at LBA 0
10:09:57.234 Info Write started 1946064 sectors to write
10:09:57.225 Info Init DVD+R: Success
10:09:57.216 Warning Laser Power Calibration Failed: 00 00 00 [READY]
10:09:57.199 Info Write speed set at x2.4 (3324 kB/s)
10:09:57.187 Info Available write speed: x2.4 (3324 kB/s) *
10:09:57.171 Info Media ID: RITEK-F16-01
10:09:57.105 Info Scanned files #63, folder #2 - total size 3984326656 b. (3.71 GB.)
10:09:57.098 Info Inserted media type : dvd+r
10:09:57.089 Info Volume ID: 1920x1080 - Part 2 my uncle Mauricio makes me totally his - XVIDEOS.COM
10:09:57.072 Info Folder: C:\Users\judge\Documents\ConvertXToDVD\1920x1080 - Part 2 my uncle Mauricio makes me totally his - XVIDEOS.COM\
10:09:57.065 Info Write started
10:09:55.969 Info DVD Video burn process started
10:09:40.998 Info Writable disc dvd+r inserted. Ready to write
10:09:38.973 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
10:09:38.973 Info Drive has IDE-ATAPI physical interface
10:09:38.973 Info New Drive selected : [F] MATSHITA DVD-RAM UJ-831Sa 1.01 (USB)
10:08:39.654 Info 1 writer(s) found.
10:08:39.647 Group Burn engine events
Katia
Re: problems abound
Post by Katia »
You have laser power calibration fail each time you start the burning:
Burner analyzes the disc before using it to calibrate its power and in your case it fails, so burning is cancelled.
Reasons can be different, most often it is due to incompatibility between burner and disc, damaged (scratches, marks) or poor quality discs or just a dirty burner, as it is supposed in your long file.
So, check if your burner is proper (dust, pieces of paper) and that its lens is clear (you can clean your burner by blowing dry air inside), check also your burner's properties ans supported by your burner types of discs and try to use other discs and other types/brands of discs. Even in the same pack of discs some are worse than others, so different brand and manufacturer can change a lot.
VSO Support Team
Re: problems abound
Ritek are not the best medias (In my opinion).
:shock: :shock:
I only buy (online) Taiyo Yuden (TY-02 or TY-03) media IDs
Or
Verbatim with AZO dye.
I never bombed a DVD in decades ….
My personal opinion !
Note:
It even had issues writing at x2.4 :shock: :shock:
Katia
Re: problems abound
Post by Katia »
Agree with you, not the best choice of the disc brand.
We also recommend here Taiyo Yuden and Verbatim.
VSO Support Team
Nemesh
Re: problems abound
Post by Nemesh »
Real Verbatim+R DVD5 are indentified as: MCC-004-00
Re: problems abound
To help problem solve this:
Did you have the issues with your previous dvd burner? Or only with the replacement "newish" burner?
Are they the same brand blank DVDs that you used with previous burner and also with the newish burner?
Re: problems abound
If you want to keep using the Ritek discs you've invested in and want to put off replacing the drive if possible because of the cost, there may be a free fix, if it's available. Check for a firmware update for your drive. A new firmware update might update the write strategies for Ritek media for your burner and make them "work" with it.
Be aware if you're going to hunt down Verbatim DVD recordable discs, there are a few caveats. While Verbatim MCC's are the best out there, don't buy the Life Series discs you find in brick and mortar stores. Those are made by CMC and they are the worst. Even worse than Ritek. What you want are the DataLife Plus series also sometimes referred to as AZO and you generally only find those online.
judgeraye
Re: problems abound
Post by judgeraye »
thanks for all that...yeah i guess these discs are low end but a great Many of them have been without issues up to now....i opened the deck and used an air blower, blew on it myself, used a cloth for my eyeglasses, used an alcohol tissue for my eyeglasses. It seemed to work once or twice Then stopped. I will experiment with different discs as soon as i can get them. The burner only cost like $25, but i'd hate to give up on it...i can't imagine that the lens being dirty would persist after all my cleaning attempts, but oh well. Maybe it Is the discs, i am remembering that every once in a few they would fail- anyone recomend a good disc cleaner? i used to have an old maxell CD that had a brush on part of it?some guy would start talking about what would happen next, then some music would play, then a loud dial tone...could use another one of those i guess. if they still make em
Re: problems abound
To test if the burner is faulty, you could try doing your movie on a different computer or if possible swap out the burner with another one.
Re: problems abound
To test the drive itself, you could make an investment in a USB burner. Then, you can test your discs on that. If you get, say, 3 or 5 good burns on these Riteks on the USB drive, then you can probably say it's the other burner at fault. However, if the discs fail on the USB drive, it could also mean that that USB drive has a write strategy fault in it and may be fixed with a firmware update.
