How to turn off voice saying Please Insert Media
Filmnoir1966
Post by Filmnoir1966 »
How do I turn this off it is driving me crazy?
Re: How to turn off voice saying Please Insert Media
I haven’t used this software in a really long time, but check in the settings, each voice/sounds are customizable, you should be able to remove this sound file, so nothing will play on this situation.
I can check later if you do not find it !
Katia
Post by Katia »
Go in "default settings" - "sound events".
You can uncheck "play sound events" not to have any sounds in the program.
Or you can remove just this one, in "writable disk required" section click on the button with the musical notes and the red cross on it.
VSO Support Team
Katia to the rescue :D :D
I was just about to go to printscreens since I am on the computer now, and not the iPad 8)
