Error during download phase "Erreur d'envoi des données : (12175)
TK471
Post by TK471 »
Hello, I am just finally coming back after getting my account enabled (thank you). I have tried over the past few weeks to update the engine for VSO Downloader 6.0.0.107, but I always get an error that complains about internet not being up, but I am in fact connected. I have a screenshot, but looks only a link can post. I have tried to re-install, but the error remains the same.
The message states:
"There was an error during the update operation. See below
Error during download phase "Erreur d'envoi des données : (12175) A security error occurred". Maybe your internet connection is gone.
Update process has failed."
I have re-installed as stated as administrator.
Merci beaucoup.
Re: Error during download phase "Erreur d'envoi des données : (12175)
Bonjour, hello…
With the latest v6.0.0.7 installer, try a frech (Clean) install by selecting
[x] Delete installation folder
Select ALL options
See if this clears things up.
Also ensure your antivirus software is not blocking the engine updater etc…
Keep us posted on your results
TK471
Post by TK471 »
Bonjour.
I tried to re-install with the recommendations (having un-installed previous versions first), and I am met with an error different from before:
(using installed 6.0.0.70)
'Problem missing binaries: update server may be down. Please retry later."
I have a good internet connection, and temporarily (10 min) disabled the anti-virus during the install (also tried with a temporary disable of the firewall.
Merci beaucoup.
ps. I may try an earlier version on the download list. (I tried a few others, always the same error).
Katia
Post by Katia »
There was effectively a problem with our server yesterday. Today all works, normally.
Please try to install and activate again: https://download.vso-software.fr/archiv ... .0.107.exe
VSO Support Team
TK471
Post by TK471 »
Hello, just wanted to report back that I get the same errors, even with the server being fixed. AV temp off, Firewall temp off, installed as Admin, ran as Admin, had re-installed with clearing - out settings. Computer had already been rebooted a few times. At some point, I may try this on another computer, just not sure when. Merci.
Very sad to hear this :cry:
Let’s see what Katia says …
Can you offer VSO some details please ?
Windows 10 / 11 ?
Have all the latest Windows update ?
This is bizarre, i never encountered any issues like this :roll:
Katia,
Is the VSO Remover tool still exists & supports Downloader ?
I would suggest a 100% clean off this machine, everything, all traces in the registry etc…
Katia
Post by Katia »
TK471, please send your screenshot and also your computer ID to support@vsosoftware.fr
You can find computer ID if you click on the icon of person at top left:
VSO Support Team
TK471
Post by TK471 »
Merci, I have sent the email as suggested with the screenshots of license and the errors. I have been working on cleaning out the OS hard drive (Win10 Pro 21H2) as I may try to do a fresh install (re-install) and see if 'new' helps, but this may take me some time.
TK471
Post by TK471 »
This one can be closed out.... I re-installed windows, and then everything else, and of course, now working. A bit of a hassle to go that far, but it was necessary. Merci!
Rexxon
Post by Rexxon »
In my desktop computer (Windows 10 Pro 64), today after starting VSO Downloader 6 - the new version was available for download.
After downloading updates - version 6.0.0.111 and language pack - VSO downloader 6 was successfully upgraded to version 6.0.0.111 ... :)
No errors...
VSO Downloader user from September, 2011 - starting from version v. 1.4.0.37
