Upgraded from GTX 1080 to RTX 4090 - hoping that Convert X to Video 2 will at least continue to work (and a lot faster due to more CUDA cores). Well, 1080 was working with older driver (the newer ones crashed CX2V.)
Sad news to report. CX2V doesn't work with 4090. Even with hardware settings off, it still crashes.
I have DVD Fab 13 but CX2V is so much easier to use (when creating a blu-ray disk of a t.v. show) and CX2V does beautiful burned-in subtitles.. but I have to use DVDF 13 for now. (It processes the video files at 735 FPS by the way).
i7 with 32 G of RAM and Windows 11 64 bit Pro
RTX 4090
Re: RTX 4090
ConvertXtoVideo is a 32 bit apps and is getting quite old.
VSO UHD was released, fully 64bits, support 4k,8k, 12k+ ratios, all audio and video streams etc...
It will be the baseline for all new version of UHD and/or the baseline for all new software to come from VSO.
I would try UHD and see what works and what doesn't with this new video card.
Check/test the encoders etc...
"I think" the plan may not be a new application for ConvertXtoVideo but way more enhancements to UHD, more outputs, maybe menu creation etc...
Keep in mind, there is NVIDIA Hardware encoders/decoders issues with their latest driver, the issues is *NOT* VSO's fault, NVIDIA changed some stuff in their drivers it seems...
Let's see what the future holds for us VSO Software users !
My 2 cents...
My 2 cents...
Got it to work!
Well - got it to work. Upgraded the mother board and CPU to i9 14900k. I had a choice between this i9 CPU - one with graphic built in and one without ($40 difference), so I thought why not?
The hardware acc setting (not RTX 4090) works. Am pretty happy, hopefully the upgrade / update may fix the CUDA version.
Re: RTX 4090
Very happy you found a working solution !
Hopefully when VSO releases new version (or new software) to convert, hardware issues will be resolved.
As mentioned earlier, nVidia did change their internal coding on latest drivers so nothing VSO can do (for now) !
