ConvertxtoDvD
moxley108
ConvertxtoDvD
Post by moxley108 »
Hi Guys please have a look at attachment please
The box above edit menu does not expand to allow three lines of text ie DVD and Menu options ,Project name or Menu template.
Would very grateful if you could point me in the area of the sizing button and as you can see the icons and slider are tiny.
Windows 11 is my choice of operating system
Martin Wood
moxley108@msn.com
Re: ConvertxtoDvD
viewtopic.php?p=109749#p109749
Please see prior post you started regarding this issue.
VSO has not started to work on ConvertXtoDVD yet, and your bug report I created for you still has not been looked into.
Hopefully for you VSO will fix this soon for you.
