Damn we have a problem
moxley108
Post by moxley108 »
Seasons Greetings everyone
The problem I have is I'm trying to put road house on disc but the sexy voice damn we have a problem and the software is quoting numbers of total chapters limit which only 99.Ive never messed with chapter numbers I only ever have put software to computer and pressed convert what it does in the background is up to the software.
,please could you put me out of my misery
Martin Wood
moxley108@msn.com
Katia
Re: Damn we have a problem
Post by Katia »
The dvd format allows to have 99 chapters maximum. Your file has more than 99 chapters, so some chapter marks will be deleted.
This is just a message to make you aware of this, you can close it and continue your work.
VSO Support Team
It's a TAD unusual that a movie that should be like 90 minutes has 99 chapters. That equates to a chapter mark at less than a minute into the movie. Unless the source is a container and not a VIDEO_TS. Then whoever authored it as an MKV might have made a dumb choice like that to put in more than 99 chapters.
CXD is returning the correct running time for the source input you added, correct?
moxley108
Post by moxley108 »
It wouldnt put anything to disc it was a waste of time and a disc.
Anyway thanks for the help its nice to know its not me .......
Well, that makes even less sense. If it wouldn't put anything to disc, how could it have wasted a disc? Did CXD write something but the disc wouldn't play? Or did the disc not complete burning?
That's one of the reasons why I have CXD write a VIDEO_TS folder output and I burn that output to disc with ImgBurn. That way, I can preview CXD's output on my PC before burning the final disc to make sure the VIDEO_TS folder appears okay.
go to settings/ options for Chapters, and untick "use original chapter points if available"
