Help please! Serious coding and virtual memory problems.
Luciano Pereira
Post by Luciano Pereira »
Good morning!
Unfortunately I have been having a lot of problems with the convertxtoHD3 software. I used the version with the end 77, but the program has problems with low virtual memory, and many, many problems encoding files, giving errors and interrupting the process in all recent tests. and the log does not show in detail the type of problem that occurred.
I updated to the latest version, and the problems still persist, and the encoding process is interrupted due to the program's lack of memory, in addition to the menu having problems, with the image becoming blurry, and with poor quality.
I don't know what else to do, as it seems that the program has been abandoned, without support and without updates for over a year.
Re: Help please! Serious coding and virtual memory problems.
The 64 bits version of this software should be released this year. Keep in mind there is only 1 developer so we need to be patient :shock:
It should have a new encoding engine using the latest ffmpeg version so lots of new support for input files, rumours are that the 64 bits can implement better hardware encoding since NVIDIA broke it for VSO and not the other way around.
So let’s wait for the 64 bits version, which should resolve several limitation issues since it’s 32 bits.
My 2 cents…
Luciano Pereira
I hope so. But it's a long year yet, and I need to use the software often. I have Amd Radeon, and the problems seem to be the same.
