ConvertX2DVD 7.5.0.129 crashes
Fump
Post by Fump »
Hi community,
when I run ConvertX2DVD 7.5.0.129 and try to change the working folder in the settings the program crashes.
I run win 11 with all Updates. Never had this before and use VSO since decades.
ConvertXtoDVD 7_mainlog.20250509.162204.297.log
(9.88 KiB) Downloaded 136 times
Re: ConvertX2DVD 7.5.0.129 crashes
Fump wrote: Fri May 09, 2025 2:38 pm Hi community,
Ohhh CONFIRMED on my machine also (Windows 10 64 bits)
I had mine set a way back so never re-tested this feature.
I will open a URGENT Bug fix to VSO !
BUG Report Created --> https://bugs.vso-software.fr/view.php?id=14499
VSO ConvertXtoDVD v7.5.0.129 Changing Working Folder HANG the application.jpg
If you guys/ladies are tech savy and not scrared to go in the registry, you could change your Working_Folder here...
If you are NOT a technical person, DO NOT PLAY AROUND with .REG nor edit the registry !!!
Code: Select all
Windows Registry Editor Version 5.00
[code]Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\SOFTWARE\VSO\ConvertXToDVD\7]
"Gen_Workingfolder"="D:\\#ConvertXtoDVD_Outputs"
Change MY folder to your own !
Save to Output_Folder.REG
Add your folder here, don't forget the \\ if you use it saved in a .REG file, else modify it manually directly in the registry
Jacques (VSO)
Post by Jacques (VSO) »
Cougar_II wrote: Fri May 09, 2025 3:23 pm
Found it (a 64 bits port issue) and it'll be in the next release to come very soon
Jacques.
VSO Software Team Member
Jacques (VSO)
Jacques (VSO) wrote: Thu May 15, 2025 11:38 am
Update has been release. Download it from here:
https://download.vso-software.fr/archiv ... .0.130.exe
Jacques.
