ConvertXto HD3
rhagar
ConvertXto HD3
Post by rhagar »
How do you tell the latest version that can be used with your key?
Re: ConvertXto HD3
rhagar wrote: Fri May 30, 2025 8:49 pm How do you tell the latest version that can be used with your key?
I have asked VSO to comment and give you the proper answer, as I am a GOLD MEMBER, I am unsure how the new 1 year subscription method works…
Katia
Re: ConvertXto HD3
Post by Katia »
If you are gold member or you have a license with lifetime updates any version can be used with your key.
If you have a regular license with one year of updates, you can use program versions released during this year of updates.
You can get the last available version for your license on our support page: https://en.vso-software.fr/support.php
Or by contacting our support team at support@vsosoftware.fr
P.S. If all of your VSO licenses are attached to the same email address that you use on this forum, the last version of ConvertXtoHD you can use is the version 3.0.0.71.
It can be downloaded here: https://download.vso-software.fr/archiv ... 0.0.71.exe
VSO Support Team
