Menu Guide: Minimal Menu With Background Image
Locked
Here's a quick guide on how to create a menu using the Minimal Template, and using a custom background image:
Step 1: Select the "Minimal, the most simple menu Template"
Set the Disk Name, this is what the DVD Label will be if you use "Auto Burning".
Step 2: Set your Main Menu Title, the big one on top !
Step 3: Highlight "Background Video in title menu"
Press <F2> to edit !
In Step 3b, the value beside it, is the Opacity
100 = Show me the image 100% clear (Full Colors)
I have mine set to 50, to the image will be 50% transparent...
Step 4: Set your Text (Input File Title to be displayed) for each input file.
In my example, I only have 1 input file.
(Rihanna) Don't Stop The Music.mpg
As you can see the .mpg extension is not displayed.
Now this file, I want the text for this video to be called:
Fishing Trip At The Lake
Step 5: Convert and enjoy a beautiful menu !
Step05 (End Result).jpg (227.88 KiB) Viewed 16940 times
Locked
